TH-18 Flat to 35hz! (Xoc1's design)
Here's my build using 4ohm B&C SW115's and Djim's cone correction - these subs get crazy loud and clear outside!
Here's a video of some hard kick drum hits outside:
https://youtu.be/A1O2lH6p7kk
Feel free to ask me any questions about building them!
I have 1.4 meters between the mouths. (340/60/4) speed of sound/freq/quarter wavelength.
How do you calculate?
Any recommendations to a good overall center frequency?
I know its not an ideal setup, but realistic. Cluster might get you a better performance, but normally I have a stage in between the subs.
Input is very welcome thank you.
I am planning to do measurements next weekend. If you have suggestions to different setups, feel free to share and I will share the results.
/ Andy
Sent from my iPhone using Tapatalk
/ Andy
i usualy do 2 meters center>center 6ms delay front sub=~40 hz center freq.
formula
for 60hz its about 4ms delay
Which version is in the quote below?
It has the ply sitting closer to the cone for cone-correction, making the horn a tiny it longer too, smart.
I've seen several versions in this thread now!
The one quoted below (looks clever but tight)
The one i page 1
Neo dans here:
http://www.diyaudio.com/forums/subwoofers/190635-th-18-flat-35hz-xoc1s-design-179.html#post4037197
And Djim's here:
http://www.diyaudio.com/forums/subwoofers/190635-th-18-flat-35hz-xoc1s-design-197.html#post4281947
Then there's post 1611, 1612, 1633
Which is better=?
When the jam breaks, the bass it will drop.
It's been a whirlwind 3 weeks building these TH18. I did a quick shootout against my old 40 Hz boxes to break in the new ones playing some Metallica before their first use. I was quite pleased with the results. Subjectivey, they seem every bit as sensitive and go a bit deeper than the front loaders they replace even though they model to the same 40 Hz in a quad. I was even more pleased Friday night. Really simple alignment - adjusted the delay to 8.5ms and actually took 3dB off the old setup. Cranked up the B&C's in the THs run STONE COLD, where the old boxes would get blazing hot on top and noticeably lose SPL over the course of 2 hours. Quite a bit more than equivalently-pushed labhorns, in fact.
Fortunately, I have some line arrays to build before I have to decide whether to build more of the same or look into bigger boxes using those same drivers.
They are really nice and easy to move around.
@Andy: where do you store yours?
I'm in Denmark too, would love to have a listen!
