i made one more PCB .
Here drivers are BD139 and BD140 .
Lamp in primer on transformator glow high .
There is no trimer because i use potentiometer with wires .
All jumpers are there ....
sir take your time, the first time I power up my AX-14 I have a problem of a short from the screw holes it was touching the heat sink I just cleaned with a drill and all good to go 🙂
OK, here for all they want to have fun the files for printing 😉
Nice amplifier again. Thanks to Mile.
regards Olaf
Thank you for this pcb design and test.
regards Olaf
Hi Olaf,
Would you mind posting a mirror silk?
Thanks, Terry
Hi, is this ok?Hi Olaf,
Thanks, Terry
regards Olaf
sir , i don`t have any screws in my PCB .
Now i take off all transistors . Every one from them is in perfect condition .....
And now i realy dont have idea what to do .....
This simple amplifier isn`t so simple 🙂
uhmm ....
Juan
Can I ask if 2SA1535 and 2SC3944 are suitable replacements for 2SA968 and 2SC2238? these are stocked by my local store.
Hi, is this ok?
regards Olaf
Yes!
Thanks @olafk......
@ still4given you're so fast......The maximum power supply for Ax14 is ....?
Dan
Dan
A 14V 20kHz sinewave is a heavy signal for a Zobel resistor.Hi, do you mean that it is normal at 20kHz and high amplitude?
With normal music and lower frequency square wave all is cool.
A 20kHz squarewave sends out double the power (into a resistor) and all that extra power is @ or above 60kHz.
That results in a lot of heat. But it gets worse than that. The capacitor reactance gets lower as the harmonics rise and this results in more than double the power into the Zobel resistor.
Hi Andrew, thanks for the explanation.A 14V 20kHz sinewave is a heavy signal for a Zobel resistor.
regards Olaf
That's really fast! Looks good!In the morning I will cut a heatsink angle and install the drivers and outputs. I'll let you know when it's singing.
I'm curious what you say about the sound.
regards Olaf
Yes, that is the original circuit.@olafk , can I use 2sa1837/2sc4793 instead of 2sa968/2SC2238?
Thanks.
regards Olaf
Is sound same as your first A14 from post #3990?
Exactly!Is sound same as your first A14 from post #3990?
But sound is very subjective.
A14 has not so much individuality and character like a A9 😎. It's more a general purpose amplifier. Neutral and balanced across all frequency ranges.
regards Olaf
finally worked !!!
Problem was faкe transistors 2N5401.
Now all signal transistors are BCXXX .
I have made six chanels
- 100W Ultimate Fidelity Amplifier
