AK4490 USB Dac with dsd support.
Holes are 3.2mm in the board.
Documents:
MIRAND USB DAC Mainboard V1.0 Revision 240515
Output shield schematic
Note: I am making a document for the shield board as well.
Driver for windows and document will be supplied on a USB stick.
  • MIRAND USB DAC V10 document release 240515.pdf
  • USB DAC output stage shield single ended V1.0.pdf
Sonny, I have read your DAC 1.0 document. I saw a preamp connector-J5, which means you are developing a preamp between DAC and Power Amp, right?
Would you please describe your preamp project, discrete or op-amp? with an analog R2R or IC type volume control?Balanced?...
You are right.
I have not decided yet if it is Discrete or opamp. I have an discrete opamp solution, and it cost the same as the opamp ADA4627-1. So it is the sound quality it depends on.
I also have an "discrete" R2R solution, but it is expensive to make, compared to an IC based solution. This two factors i have not decided on yet.
It will have single ended inputs, and 1 balanced input. 1 balanced output and 1 single ended output.
You are right.
waiting...:D
