I was going to go on about power supplies if the OPINIONS on DA are done.
Attached is a basic power supply as JC sort of has shown here.
Really? I have not seen any proof that DA is the distortion mechanism.
That's why I said 'postulated'.
AFAIK aso there are no formal 'proofs' of DA causing throughput distortion.
I have also made a lot of capacitor measurements, but would not say distortion was a result of DA.
After digesting your measurements over I expect a wide range of capacitor types, do you have reasons for capacitor throughout distortion ?.
DA makes longterm time domain errors, in frequency domain errors at very low frequencies, most probably linear errors rather than non-linear distortion.
That's why i mentioned level/operating point shifting...this can cause dynamic long period distortion spectrum changes.
Dan.
Originally Posted by PMA View Post
There are known non-linearities of dielectrics:
dC/dT (temperature)
dC/dV (voltage)
dC/df (frequency)
dC/humidity
DA does not seem to be the cause of any above.
What is meant by dC/df (frequency) non-linearity ?.
Is DA not a VLF non-linearity ?.
Dan.
DA in those C elcaps? 🙂
Would not you rather take care about diode switching transients? 😉
You raise a good issue. Standard practice is to put capacitors across each diode. I have seen 10 nF suggested as the value.
JC of course uses a diode that has low switching noise.
I forgot to make one thing clear, this discussion is about low power supplies as would be used in preamps!
There are so many places to start the discussion.
AC mains noise?
Avoiding unbalancing the transformer?
Diode noise?
Transformer noise?
Surge currents?
Ripple?
Filtering vs frequency?
Circuit theory components not shown in the schematic?
ES
So what really is DA ?.
A cap can be shorted for a relatively long period and then return a voltage ramp.
Why ?.
Ok, simple description.
A capacitor is essentially two conductive plates separated by an insulator (dielectric). When you charge a capacitor by putting a voltage across it, you're basically sucking electrons off one of the plates and shoving them onto the other plate. So now one plate has a net positive charge from removing some of its electrons, and the other plate has a net negative charge from putting an excess of electrons on it.
So now you have a force between the plates as the positive plate is pulling at all those electrons on the negative plate to try and equalize the charge.
Dielectrics are insulators, but they're not perfect insulators. And some of those electrons on the negative plate will slowly move into the dielectric. Sort of like a sponge, which is why DA is also referred to as "soakage."
However the movement of electrons into the dielectric is very slow. So if you short the capacitor and discharge it for a shorter period of time than you charged it, not all of those electrons in the dielectric will have had a chance to make it back to the conductive plate.
This gradually happens once you open the circuit again, and now the negative plate, which had equalized its charge with the positive plate during the short, begins to become more negative again as the electrons that were absorbed into the dielectric previously return to the plate, and so you begin to see a rising voltage across the cap.
I'm pretty sure this is a pretty accurate description of the phenomenon. I'm sure SY will correct me if it's not. 😀
se
So how does DA cause distortion, if indeed it is a cause.
Mr RNMarsh (also JC,SW, Bateman and others) has done measurements and come up with the postulation that DA is one cause of throughput distortion in capacitors of various dielectrics.
The notion that a capacitor can be briefly dead shorted, and then delayed wrt the initial short circuit event return a positive, albeit high impedance voltage/energy output implies some kind of return energy slew rate function/limitation.
This effectively very slow slew rate function could cause subtle level shifting of DC operating points in the presence of asymmetric signals....IOW audio signal and not sine test tone signals.
Dan.
Ahhh. A couple thinkers in the crowd..... First off, you have to realize that energy stored in the Cda portion(s) is not readily available and is subtracted, if you will, from the total energy applied. Can the output then be exactly the same as the input in real time?
Later, the soaked-up energy is released into the external circuit at the Time Constant of the RC rep DA and the external Z.
For the thinkers.... how much later? Suppose a uni-polar impulse waveform with a period within the audio range. Will the DA/TC release modify the original waveform? How so? This one form of distortion.
The primary comparison was bipolar vs film..... that was the issue of the day. So, in your model, use a bipolar cap.
THx-RNMarsh
Ahhh. A thinker in the crowd..... First off, you have to realize that energy stored in the Cda portion is not readily available and is subtracted, if you will, from the total energy applied. Can the output then be exactly the same as the input in real time?
For the thinkers.... how much later? Suppose a uni-polar impulse waveform with a period within the audio range. Will the TC release modify the original waveform? How so?
So where's the non-linearity?
se
