"Compact" VFA
I spent a little more time for more cosmetics changes on board. These has lost 2 more mm in length but much effort has been spend to avoid layer swap on tracks
Marc
Thx for the heads up on Futurelec, some things are in the "to good to be true category"
Rds, lets see if I have this correct
2sk117: Idss at 10V Vds = 1.2 - 14 mA
10/1.2mA = 8.333K ohm
10/14mA = 714 ohm
For 2n4340-4341
Drain Source ON Resistance rds(on) 1500 - 800ohm VGS = ØV, ID = Ø A f = 1 kHz
Drain Saturation Current (Pulsed) IDSS
4340 = 1.2-3.6 mA
15V/1.2mA = 12.5K ohm
15V/3.6mA = 4166 ohm
4341 = 3-9 mA for VDS = 15V, VGS = ØV
15V/3mA = 5000 ohm
15V/9mA = 1666 ohm
Seems to be less spread for the 2n4340-4341, but rds is higher for sure.
In overall, 2N4338-4341 is a very good low noise series of jfets.
2N4338 will work here with the following adjustments (schematic from the POST#88):
R5 = 0 (jumpered);
C14 = 6.8pF
All the others from this series (4339-4341) have got too positive source potential (higher bias, especially 4341), that can be compensated by additional diode or LED in series with the source (the closer the feedback return point to zero - the better). So - possible, but requires additional testing.
I built my first singleton, using a 2n4393 followed by a NE5533(dual) RIAA phono stage, it sounded pretty good.
Any idea how Semelab ALF16N16W/ALF16P16W would fair in this design? I know that the bias generator can be simplified, to passive R's, any anticipated compensation changes?
ALLFET IPS
New project in the Compact VFA series. FET-o-mania 😛
4 MOSFETs, relatively high-current operation. High linearity, low distortion, good stability margins, rather simple though. Bootstrap.
Planned for using with TubSumo Lateral FET OPS (schematic is attached for your reference). Power supply voltage +/-50V.
Developing a through-hole PCB for initial testing.
