Well I finally finished my A40. I had initially Used 2SA1320-Y/C3423-Y for the VAS and I just couldn't get it working. I got in some more MJE340/350 so I changed those out and now the amp plays perfectly as one would expect. Listening to it all morning. Another winner!
Blessings, Terry
Blessings, Terry
Blessings, Terry
I'm glad to hear it's working , sound it's perfect even without ton correction 😎 I hope you understand why I added at offset ,one more capacitor .....🙂
Have you change 470 ohm resistor to 470K in offset adjust circuit?
Regards,Alex
Regards,Alex
Hi Alex,
Yes I did see Mile's post about the 470K change. The board is set up per the silk except I used those 2SA1360/C3423 for the thermal transistors. I will probably change those too because the bias takes a long time to settle and I think thy maybe to blame. I also used MJL4281/4302 for the outputs. I running it on +-60V rails and it isn't breaking a sweat.
I figured the back opposite facing polar caps on the NFB were to take the place of a non-polar. Cheaper option.
U2 Terry... I have to ask you Terry, do you have for each day different amp?
Lol, I suppose I could but I have about 7 amps stacked up next to my work bench that I switch between.
The high Cob of the slow transistors may be adding compensation that ends up just about right............... I had initially Used 2SA1320-Y/C3423-Y for the VAS and I just couldn't get it working. I got in some more MJE340/350 so I changed those out and now the amp plays perfectly................
Hello guys here is AX-14 that I did and just change the size of some 1/4W resistor macros so the can fit better also I will share Sprint file so you guys can used as reference for other projects please used only for diy 😎 I do this because I do love this hobby
have fun with it 🙂
Juan
have fun with it 🙂
Juan
Hi Terry and all,
did you try using ksa1381/ksc3503 for the drivers?
I find in sims that they usually give an amp slightly better performance.
Since you posted your impressions of AX-14 and OS slewmaster, I did some sims comparing against original AX-14 and other designs to see what is going on.
It would be cool to compare sims vs real life testing just to refine the design process.
Do you actual own a distortion test setup?
I wanted to figure out in sim, why people praise one topology vs another. Just for the fun of it of course.
I wonder if Mile, does any design sim at all or all pen/paper,testing?
where the inspiration comes from, just dreams these circuits up or looks at other designs as references, to get ideas?
btw, in my sims I have also looked at SF3.1 pre-amp, what is impressive is how it clips!! all nicely rounded edges, no flat lines what so ever. i will try the bjt version, sb3.1 to compare.
A ? for Mile, for sf3.1 the output jfets are in a common source or drain configuration? I do realize that many mfg say that s/d are inter-changable. Comparing against sb3.1 I assume a common drain config like the common collect in sb3.1.
thx Rick
thx Rick
Do not be a problem with bias if the driver (Q13,Q11) are not on the same heatsink with Q14,Q12?
AX-14
AX-14
Hi Rick,
I did not try the KSA1381/KSC3503. I suppose I could try them now that I have it working. I can't be sure that the 2SA/2SC were the problem. I changed them out on one of the boards because the board wasn't working and the MJE's were what was called out on the screen print. After I changed them and there was still issues so I went over the board again with a diode tester and discovered I had one diode reversed on both boards. When I flipped the diode the board with the MJE340/350 worked and the other one didn't. At that point I changed out the pre-drivers to MJE and at the same time I reflowed all of the solder joints on the whole board. After that the board worked but I don't know for sure if it was the transistor change or the reflow. I won't have time today but tomorrow I will change them back or even install the KSA/C devices and see how that goes. I would hate for someone to go to a lot of trouble finding a certain device if it is not necessary.
I don't have distortion testing equipment. The guy to go to is Thimios. He is a much better tester and builder than I am.
Just finished ...after few my mistakes is running.... Offset is OK, but bias still no OK. When I set bias 50mA, after On/Off procedure is 100 mA and slowly decreasing back to 50mA...maybe some temperature compensation, or something totally different 🙂 I have to check it tomorrow..
Come on Terry we are students every day😉Hi Rick,
Andrew said it right,slower transistor acts as faster with added compensation. as i have read (not much to be sincerely) that is most common thing happening when output transistors from vintage amplifiers were replaced with newer that have lower parasit capacitance - an amplifier starts to oscilate - and problem is most commonly solved by adding some compensation to those newer transistors,to make them slower.
faster transistor on wrong place can make troubles...
P30 meets A40. Ooo-la-la! Pure Apex/Alex blend.
A40, +- 60v rails
P30 +- 22v rails.
Highly recommended.
With MM28 it will be pure CFA pre/amp amplification.
- 100W Ultimate Fidelity Amplifier
