Class D Amp with LM566, LM393 and 2XIRF530
i redraw the schematic of mr apex d200 and rename the parts.. sir apex can you take a look if i miss something
Hi Dacz,
Remove R13&R12 and R11 is 1K/2W C25 is 100pF/100V R21&R20 is 6K8/2W R14 change to 60K (Parallel 100K & 150K) and Remove C2, R2 is 1K2 remove R23 & Provide Zener 15V parallel C13 & L1 is 22uH, 0.22uF/400V use C27 Parallel & .Now the audio will good & use 330R/2W series with Q4 Collector { Now you can use IRFP250N}.
MANOJ
Hi Apex,
I've test my D200 this morning... I play it in 30minute the inductor is hot i used sendust core as will the 10ohms in zobel is hot.. sound very good very clear... I plan to change the inductor with T106-6, but I notice the out put power is low i think is about 40-50watt.. it is ok to change the feedback resistor into 100k to achive higher gain just like other d-amps?
Hi Apex,
No, just replace inductor.
Has anyone made a comparable measurements between using gapped EE flyback traffo & iron powders as output inductors? I made some listening test and it seems, the gapped EE ferrite performs really good as well. It is definitely cold probably colder than the T106-2. I experimented another EE same size as flyback traffo but ungapped, I did however made a 1mm gap on one leg and it surprisingly performs very good as well.
