Hermes-BBB/Botic cape for BeagleBone Black
BTW, I'm still using software clock divider by miero instead of H/W divider on the board. If I'm going to use the latter, I think that there is no necessity to edit kernel option for clock rate setting. Correct?
Best Regards,
You should definitely use the hardware divider on the cronus - because the input on the BBB are only rated for 25Mhz - exceeding that is not a good idea and could not possibly have any positive effects. And yes if you use 22/24Mhz input you can use the normal clock settings on Botic.
Thanks for the report!
Cheers!
Russ
Up & running, making exquisite music (Mark Knopfler,Tracker).
Many thanks to all at TPA, et al for making this possible.
I don't think that digital music can sound better than this,but then again TPA keeps confounding us.
Only two small problems in the build, the back-up battery leads are very
thin so I had to resort to extending them with thicker wire to clamp them properly in the terminal block & I got the divider selector in the wrong position resulting in 'chipmunk' sounding music.
Synology NAS,ethernet,BBB,Hermes,Cronus,Teleporter,
Teleporter,Dual B-iii,Legato,Mono N-Core 400s,Shahinian Obelisks.
Well done, Russ, Brian & Miero.
jtr.
The teleporter setup is completely optional (but very cool) - it is just a nice way to completely separate the source from the DAC - it has the advantage that you can put the DAC and the Cronus/Hermes is two completely separate cases. Teleporter is designed to transport the signals cleanly using LVDS over ethernet cables - the latest teleporter version supports shielded cat5/6 cables. It is a superb way to move audio signals around while maintaining ultra low phase noise.
In my case I have to find the easiest way to send LVDS to W4S HDMI I2S input, similar I think to PS Audio set-up?
Hi, Druidaudio. Yes, I use Teleporters to carry I2S between player & dacs. The receiving Teleporter output conveniently splits the signal to the two B-IIIs.
Very versatile modules that could be used for isolation within single large unit.
IMHO BBB,Hermes,Cronus is a very significant improvement in terms of musical enjoyment, over my previous RaspberryPi/I2S player that Russ started us off with. Well worth waiting for.
jtr.
The PS Audio I2S-over-LVDS method is discussed on the forum here -
http://www.diyaudio.com/forums/digital-source/237690-ps-audio-i2s-interface.html#post3645239
If PS Audio's use of LVDS is equivalent to the TPA Teleporter (it would certainly be worth checking)
then your Cronus-to-HDMI connections should be -
MCK to pin 10 (TMDS Clock+)
GND to pin 12 (TMDS Clock-)
BCK to pin 4 (TMDS Data1+)
GND to pin 6 (TMDS Data1-)
D1 to pin 9 (TMDS Data0-)
GND to pin 7 (TMDS Data0+)
D2 to pin 3 (TMDS Data2-)
GND to pin 1 (TMDS Data 2+)
connecting to dddac1794
I have the boards soldered and connected to the BBB. Botic is running dut I did no configurations yet.
How do I connect Cronus to my dac?
Cronus outputs: U_MCK, DCK, D1, D2
Dac inputs: BCK, LRC, Data, (MCK)
I have tried different configurations but only static noise is generated.
Hi Russ,
Thanks for your fast reply! Will try your advice right away!
The dac is DDDAC; a NOS dac design with PCM1794.
I have swiched to 1:2 (my bad) and soldered the leds to the board to see if there is a connection faillure with enable led. After soldering still led is still not on.
