The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
Interest List SC-cut Crystals from Laptech
- andrea_mori: 2 x 11.2896 MHz + 2 x 22.5792 MHz + 2 x 24.576 MHz + 1 x 45.1584 Mhz + 1 x 49.152 MHz
- Acko: 1 x 45.1584 MHz + 1 x 49.152MHz
- iancanada: 1 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152MHz
- babaudio : 2 x 22.5792 MHz + 2 x 24.576 MHz
- Clsidxxl: 1 x 22.5792 MHz + 1 x 24.576 MHz
- lindamar: 1 x 11.2896 MHz 1 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152MHz
- tagheuer: 1 x 45.1584 MHz + 1 x 49.152MHz
- palmito: 1 x 45.1584 MHz + 1 x 49.152MHz
- damohpi: 1x 11.2896 Mhz (or 2x if reqd.)
- Naimster: 1 x 22.5792 MHz + 1 x 24.576 MHz
- noizas: 1 x 11.2896 MHz + 1 x 22.5792 MHz + 1 x 45.1584 MHz + 1 x 49.152 MHz
- Phi: 1 x 22.5792 MHz + 1 x 24.576 MHz (Added title )
- stijn001: 1 x 45.1584 MHz + 1 x 49.152MHz
- ambrosia168: 1 x 11.2896 Mhz + 1 x 22.5792 MHz + 1 x 24.576
- flowerpot: 1 x 45.1584 MHz + 1 x 49.152MHz + 2 x PCB + 1 x daughter board + 2 x DIL
- jdlvfr: 2 x 11.2896 Mhz
- tods: 1 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 MHz + 1 x 49.152MHz
- wlowes: 1 x 45.1584 MHz + 1 x 49.152MHz
- fralippo: 1 x 45.1584 MHz + 1 x 49.152MHz + PCBs
- duster1: 1 x 45.1584 MHz + 1 x 49.152MHz + PCBs
- deanoUK: 1 x 45.1584 MHz + 1 x 49.152MHz
Second batch AT-cut Crystals from Laptech
- Miklos: 1 x 16.9344 MHz
- Marlowe: 3 x 16.9344Mhz + 3 x 25MHz
- carz 1x 27MHz
- 1audio : 1X6.1440MHz
- mravinsky : 2 x 16.9344Mhz + (2 x TWCMC-C XO board +1 x daughter board) if possible
- noizas : 2 x 16.9344 MHz
- randytsuch: 2x 25.0000 MHz
- casshan: 1 x 11.2896 MHz + 1 x 12.288 MHz + 2 x PCB + 1 x daughter board
- ambrosia168: 1 x 45.1584 MHz + 1 x 49.152 MHz + 1 x 90.3168 MHz
- andrea_mori: 2 x 6.1440 MHz + 2 x 12.2880 MHz + 2 x 16.9344 MHz
- Fabian85: 1x 16.9344 MHz, 2x PCB + 1x daughter board
- duster1: 2 x 16.9344 MHz, 2 x PCB + 2 x daughter board
- RollE2k: 1 x 45.1584 MHz + 1 x 49.152MHz + 2x PCB + 2x daughter board
Any idea when the second batch is going to be ordered / moq reached? Do you still need the additional Excel mailed Andrea?
Fabian
MOQ for the crystal you are looking for (16.9344 MHz) was reached, but I would place a single order including other frequencies as well as SC-cut crystals, to save shipment cost.
Next days I'll publish a new sheet that includes the SC-cut type, so who are in the list could start to send me the order form.
change quantity
- ambrosia168: 1 x 11.2896 MHz + 2 x 22.5792 MHz + 1 x 24.576 MHz + 1 x 45.1584 Mhz + 1 x 49.152 MHz
- carz 1x 27MHz
Are there any frenchs whom have received their shipment ?
Korben ? I'm still waiting mine !
regards
Eldam
Hi Eldam,
Phil got his parcel yesterday, that was shipped almost a week after yours.
I have just called Poste Italiane customer service. They said your envelope has left Italy on April 9th.
If you track the package on Laposte.fr (La Boutique : suivi des envois - recherche par numéro), you see that the envelope arrived in France on April 11th.
So, I suggest you call La Poste customer service, if you have a chance.
Andrea
Hi Andrea and All,
I've been delivered yesterday, the parcel was perfectly packed thanks to Andrea's care.
Due to "declared value", I've pick it at the post office, not a usual postman delivery.
It explains the extended delay 😉
I've got "triodehunter" Form filled and recorded.
I've adjusted XO values for "lindamar" (PM)
To members "thorstenlarsen", "zenelectro" & "JethroTull", your Form is awaited 😉
Link to the Form :
https://docs.google.com/forms/d/1odqObA4PFXhxqxyqrZiAPSWgGCTsZBO19erk2LmXXHk/viewform
-> Please use Submit button when completed !
It really helps !!!
Phil
Hi Eldam, don't panic and be pessimistic.
Just wait a little bit more 😉
Phil
Hi Phil,
I will not call that Panic & pessimism ! How you see me... hey "my honor" as would say some ****** in some other thread ! Pffff.... but more organisation as now it is more than 15 days (sent theh 09 april) and I have maybe to ask.... better before one month and before Cristmass no ? ! I know both french Post and Italian one pretty well 🙄 ! Give youy an example : receive from IanCanada 2 I2StoPCM in less than 9 days, BG caps from Partconbexions in 15 days from USA
No problem, it's not like if I wait for a new hearth or some viagra pills !😀 Hope a postman didn't eat a Crystal thinking it was !😛
Well, if nothing saturday I will ask, and the problem will beginn as because the syndicate organisations you can ask nothing or this is a local strike !
@Andrea :have you please a scan of your Post form please ? Any insurance in case it's lost ? The french post tracking just give the same infos as yours, it seems it crosses the frontier... but nothing more !
@ the customs officiers : hey les gars, Vigipirate c'est pour les bombes pas pour la hifi, en plus je ne sais même pas quoi en faire ces crystaux, c'est plus pour supporter le mouvement ! Pffff ! Et en plus je suis en mini vacances dans le Périgord, non mais dressez mieux vos chiens.... rendez-moi mon paquet !
But because te Murphy law I will maybe receive the shipment tomorrow as someone has a daily look to my mailbox ! In fact it suffices you ask on a forum to receive the shipment the day after !One exception is Cristmass day ! I saw there is a certain concistency ! Despite I ask I had always received the gifts the 25 in the morning !
yes, if the price isn't too expensive.bigger than bigger!😀
Just got the quote, they are a little expensive.
5.6448M SC3 HC47
With typical parameters:
Frequency tolerance at 82C: ±1.5ppm
ESR: 125 Ohm max
C0: 3.0pF
C1: 0.15fF
LTTP: 75C to 90C
(calculated Q greater than 1.5M)
15 pcs m.o.q. CAD$70.29
100pcs CAD$44.11
lead time: 7-10weeks
As you can see MOQ is 15 pcs.
If you consider the actual exchange rate, VAT I have to pay in Italy, the final price should be around euro 66-67 each.
Hi Andrea,
So it seems the expeditor only has to ask to the Post where he putted the letter (it is where you pay for the service) ! I can't ask for you ! Italian Post will ask to the french Post as it is a registered mail with receipt with insurance (I hope so at least for me)
Am i the only one who has not received his parcel yet ?
Sorry for the troubles, let see it together after your holydays, maybe the shipment will arrive before you come back 🙂.
Eldam
Hi Andrea,
Eldam
Hi Eldam,
there is no insurance as I wrote before to collect orders, finally I shipped all the envelopes with registered mail (loosing a little money) to get a tracking number.
Seeing the tracking in other countries you are not the one still waiting for the parcel. French mail tracking is not the best, one can only see that the parcel has arrived in France, but no more infos.
Other tracking service like Royal Mail in UK gives more detailed infos.
I did call Poste Italiane, but they told me that there are no more informations after the package has arrived in France.
I think if you call La Poste asking for the tracking number I sent you, they should be able to track the package in France.
Andrea
