100W Ultimate Fidelity Amplifier
I like the performance of this protect, but it works only in rails supply up to 40VAC.
What are the changes if i want to use separate 18-0-18 up to 24-0-24 VAC in order to use in higher rails power amp?
On 560R/2W you have voltage drop to get 24V on relay coil, with 18-0-18 use short circuit instead 560R/2W and 5,6V zener instead 15V, with 24-0-24 use 20-50R instead 560R/2W, with rails up to 40vac use about 1k/5W instead 560R/2W (you must change resistor value to get 24v on relay coil). GND from separate protect psu must be conect to main gnd.
Thanks for the info Mr. Mile...
No, wrong connection .....
Regards,Alex
Thanks !
If i remember correctly you have another version based on 555 i.c.
If it so can you post this, or give the post number?
