100W Ultimate Fidelity Amplifier
I test al transistors, they all seem ok, the amp worked for a few minutes then it died, i'll post some measurements tonight.
Are these tranzistors in wrong position or they are different parts?
I've done some measurements on final transistors:
The psu in +/-30v, and on the output is 28vcc
2sa1943
GND-B-29.6v , B-E -0.02
GND-C-30 , B-C- 0.04
GND-E-29.5 , E-C-0.03
2SC5200
GND-B-29.4 , B-E 0.02
GND-C-28.9 , B-C 0.02
GND-E28.9 , E-C 0.02
2sa1943
2SC5200
Measure voltage on input and VAS transistors... check diode polarity there is mistake in first post.
2sa1943
2SC5200
Voltage reading taken incorrectly or written incorrectly.
2SA1943 collector should be negative -30v and 2SC5200 collector +30v from GND.
what psu you are using smps or transformer with bridge and filter caps.
Sonal
