Which one would we prefer to use in a linear amplifier?
Hi Michael and Diyers
Its not the one from left photo
Cwtim01 sits courves looks much better
and his 2SK182ES one are nice linear but ....??
Not expert opinion happyly thread are for talk together
and find good solutions
Best regards 🙂
Some of them might be workable for a flea-watt amp. It really comes down to what one expects for one's money. When I'm paying top dollar, I like to get the whole horse.
... Cwtim01 sits courves looks much better
Actually it's hard to say, the 2SK182ES curve I showed was spaced by 0.25V apart. For the same dataset, if I space them by 1V apart (just by remove some curves in betweem), it gives the attached.
Now it looks pretty much like the bad curve Michael has shown ..... 🙁
Yes, you are seeing my point. And, this is the "good" region. Yet, you can already see how the drain resistance is creeping up. If you could extend the voltage they will likely start to look like the photo.
To give a frame of reference at similar scale, look at my original 2SK82 curves from ages ago. See how the drain resistance is nice and consistent keeping the traces fairly parallel?
OK, so I just sent an email to eyelabo_jp, hopefully he'll be as nice and helpful to my refund request.
I am sad to hear the bad news about so many not properly working Tokins.....
Three or four times I nearly ordered some......but I still have to build my SK180 amp, so I hesitated.
I hope that in April I can report about my SK180 build with 45R drain resistance and around
80-80V PSU.
80-80V PSU.
@generg
Between some fake Sony's and my bad luck with Tokins, this month feels a little like a bad trip to Vegas.
Ah, well. I do it for the good of DIY audio. 🙂
really a pity for you, these SK182 look so heavenly and the possibility to mount them easily on normal heatsinks and their higher gain……..
hopefully at least some other guys have working parts.
Right now, Paul is the Auric Goldfinger of 2SK182ES's
It seems that most of the "good" devices we have seen are old, used and/or abused. Do these devices require a burn in period of some sort? Was it done at the factory on early devices or on a spot check basis? How would time spent at high voltage, current, frequency or temperature affect their curves?
It's more likely that some rejects have escaped.
These wouldn't even be marginally useful in some of their intended applications.
@ PSzIt seems that most of the "good" devices we have seen are old, used and/or abused. Do these devices require a burn in period of some sort? Was it done at the factory on early devices or on a spot check basis? How would time spent at high voltage, current, frequency or temperature affect their curves?
Interesting point of view.
@ Michael and Diyers
Semiconductors industry in Japan have very strict control quality. Its some national pride.
Logic say they controls are made at every step of production, transistors are marked
with brand logo and batch number and was put in box after controls at the end.
Rejected ones never see any box imho.
Its strange to have all not well working same batch & individual numbers
It was stored in clean & dry environement.
This seller send me paper box with and is smell lightly like old book.
Tokins are transistors tanks its incredible if all of my 5 are not in specifications
and all others diyers sit's from the same source.
No one ? That mystery ?
They're bad parts guys.
You're welcome to mine if you think otherwise.
Might as well throw one in the oven at 150C/300F for an hour or two and then hook source and drain in line with a 300 watt bulb and plug it in to the wall for a while just to see what happens. 🙂
- Live Lab Hangout #1.1 Posted
