Post your Solid State pics here
Year 1993 power amp
without software for pcb, all with pencil and hands,...
Reactions: ribakoff
Heatsink: yes I know but they are left-over so I had to use them somehow and I didnt wanted to slice them.
With average load they go up to 75C°... With a little fan -20C... So the airflow is pretty bad. 🙂
But I hope the high temp will produce high quality as a side effect... :-D
Layout: I had many other issues with the stability but nothing bad experience with this wiring!
And now it is rock solid finally.
Jaco wat wys jy vir die mense , Is dit die heatsinks wat horisontaal le ? Ek wonder as jy in die boonste vinne gate boor dat daar konveksie verkoeling kan wees. Dit sal mos werk.
Is it because the sinks are mounted horizontally. Drilling a few holes at the top will increase convection flow of the heat. Looks great. !
