100W Ultimate Fidelity Amplifier
Hello guys I was just playing with the Preamp SB 3.1 and A33 together 🙂
maybe .... I will make preamp SB 3.1 later 🙄
Juan
P30 is preamp made for A33 😉
In what post is the P30 mister Mile ? 🙂
yes guys :nod: I did not notice but we constantly made amps and more amps but not much about pre-amp layouts maybe a simple single side can be made to get a bit more input signal for the amps we have , my PC is my source of audio can only give some mV of output but with the pre-amp I can get about 1.5Vp out of the pre-amp but if mister Mile recommended de P30 with time I can make both, for now I'm saving some money now to order the A33 so that will be next month "maybe" so meanwhile I can spend some time making the preamp layouts with time of course 🙂
Juan
I found the P30 schematic 🙂
the supply circuit is also here in the 100W Ultimate Fidelity Amplifier thread mister Mile ? ok, ok, I will search here mister Mile I don't want to bother you too much jejejejeje 😛
Juan
Hey Terry
you where looking for a preamp ? this is not the same as the one you was looking for and I think you might want to try out, it came out too big but I think is better because that will make it a lot easier to etched the traces are lot thicker than usual I mean if you want it to try out, let me first check everything a couple of time before I post the PDF files, here is the image 🙂
maybe later or tomorrow
Juan
