CF-FET V2.0 front-end - going high-tech (SMD)
Tuned-up and re-measured
Hello All,
Added two 10pF caps to compensation scheme (C26, C27). R21, R24 = 150R (10.5mA VAS current).
Key measurements are presented below (again, in combination with directly-driven two pairs of Renesas' 2SK1058/2SJ162 Lateral FETs). All FFT spectrums are measured at 4V RMS @ 8R, square waves are 20V amplitude at the same 8R. Practically no harmonics above the 3-rd one. Note excellent phase response within the audio bandwidth. All measurements are done with the input RF filter in place - otherwise the corners would be even sharper.
I have tried measuring the same things with 6 Ohm real speaker (Monitor Audio RS-8) - practically no difference. THD is increased by less than 0.001% due to the higher load - that's it. Square waves are exactly the same.
I am more than satisfied with the results. Next move - building an SMD version. Most of the components are already in hand except the VAS FETs, coming from Mouser. Looking forward to building it :lickface:
Valery
Auditioned at normal/high listening volumes. Top resolution throughout the whole audio range, especially noticeable at highs - well, as expected. Razor-sharp clarity.
Moderately warm heatsink, very stable quiescent current. Laterals keep it themselves.
Impressive performance from a 10-transistors amplifier (6 in IPS + 4 in OPS).
Trying to re-check the bias, connecting the DMM to the powered-on amplifier (not recommended 🙂), shortened the output to the negative rail. Protection tripped right away. Light click in the speaker, and... nothing happened. It simply works after re-start. Combination of the fast protection and rugged MOSFET output = "hardcore" reliability and security for the speakers 😉
There is a barely-noticeable 50Hz buzz when "touching the speaker" with my ear. Thinking about powering the front-end from a separate regulated power supply. No "hiss" at all though - S/N ratio is over 110db.
How does it sound at low volume?
Just did some low-volume listening. I can't run direct A/B test, comparing it with CFA-CFPx2, however - it also does not go "flat" at the low volume. It looks like it is an advantage of the high-speed, flat phase-responce designs with the low-impedance feedback network. Sources stay precisely localized, somewhat accented, sharp highs stay sharp at the lower levels as wel. Overall naturality of reproduction just adds to the picture - you just want to continue listening. Easily handles complicated symphonic material, like Big Phat Band. Requires a good high-res source though - any compression artifacts become noticeable.
Just read the OS's post in his Slewmaster thread and thought - I have to test it with Alan Parsons '84. Perfect! Well, greatly mastered recording - even the bass stays prominent, regardless of how low the volume is 🙂 But this is more a merit of Alan Parsons 😉
All of A. Parson is very articulate for modern music. He puts "ghost sounds" in
the material. Some amps do these , (OEM's) usually don't. (OUR) amps DO ! ...
even some sounds I did not know were there 😱 .
Try the last album (2004 - A valid path) ... WOW , this is the bass test - "return
to tunguska" (leach amp rules here).
PS - ahh "ammonia avenue" (1984) - good one - have all 15 albums/FLAC.
OS
Interesting ! Yes . the faster amps DO stay quite the same at very low volumes.
(with an almost "haunting" soundstage).
But , the VFA's just steal the show with high output bass.
Since this is so apparent ... CFA for full range / VFA for subs ! 😀
OS
Yep, fully agree! I can't support it with a good theory yet, but it's definitely related to the way NFB operates (feedback impedance matters)...
It's in the CF node ...
VFA = B-E for feedback(subtracts through the LTP).
CFA= E -C +(B non- inv) for feedback - one device acts as the whole LTP.
CFA- group delay of <20nS . VFA = >100's of nS.
Almost no phase shift from input - output , back to NFB .
OS
OS
Yeah, 2004 is very cool. I've got it in multi-channel (DVDA) - all the "missing" channels are amplified by Audiolab 8000x7, my "assisting" amplifier (5 speakers in total, phase-aligned) - this is a complete "nirvana" 🙂 Sources can be located anywhere in 3D-space. However, the quality of two main front channels is the most important. 'Tijuania' is fantastic in this setup. As well as 'L'arc en Ciel' 😉
Audiolab 8000x7 ?? 7 channels of mt-200's ? Quite an "assisting amp" 😱
Is that where the control board "audiolab" input originates ?
I'll only end up with a 4.1 - small "slews" for the rear .
OS
Measured the second channel. Exactly the same. Same PCB, same components - soldered, switched on - that's it.
At least the TH version is sort of "productized" 🙂
Got the most of SMD parts. They look scary 😛 Most of them are very small 🙄 Ordering the PCBs...
Tested with HEex-FET OPS
While waiting for SMD PCBs and VAS MOSFETs, tested the TH version with Slewmaster-based IRFP240/9240 Hex-FET (3 pairs) OPS.
Interesting results...
Slightly more accurate square waves.
Slightly higher phase shift @ 20KHz (3.3 degrees against 2.2 degrees).
Looking at the spectrums, 3-rd harmonic and above are simply not there.
However, 2-nd harmonic is lower @ 1KHz, but slightly higher @ 10-20KHz.
Also, with 3-5 pairs, this one is capable of delivering enormous currents. 4 ohm and even 2 ohm (with 5 pairs) loads - no problem.
Overall - cool performance. At normal listening volumes it's not really possible to distinguish between Lat-FET and Hex-FET OPS boards here.
Valery
Hi Val did you finish The smd version, if so Can you tell a little of The SMD IRF's are they matching Well ..?
Hi Michael,
Not yet - PCBs are expected to come in a couple of days and I will start soldering them.
However, IRFs are coming from Mouser, and it will take at least 2-3 weeks for them to arrive.
So, the most interesting parts are the "longest" ones 🙂
I will report on the progress.
Valery
Not as difficult as expected 🙂
OK, the first one is done except the VAS MOSFETs - still waiting for Mouser to deliver. All the rest went pretty cool (the board is not cleaned from the flux yet). Got a jelly flux with very thin applicator - very useful, as it pretty much holds the part in place before it melts (the flux, not the part 😀). Also had to use a magnifying glass - especially when soldered 0603-package parts 🙂
So - waiting for the FETs, soldering the second channel board :snail:
