Mic, Line, EQ... Preamps
Hi ROhin and others,
Based on the suggestions and inputs received and also some web browsing, I have put together a small PSU PCB which will be used to drive APEX mono LM3886 amp and APEX Sub Xover. attached as a pdf file.
pl review if you find time and point out gross mistakes and suggest any corrections/ modifications.
thanks all,
prasi
thanks all,
prasi
don't try it..you cann't use one dc for preamp or crossover and amp. your 7815 will blow in first try.
PSU for amp and preamp...
you are not getting point. you can make so much different voltage from one source this is not problem.this depend on application.here your application is amp and crossover.with this type of circuit you will get noise.you have two option use two trafoo for 7815 or use this apex circuit.
According to my schematic
So, if I were to use an xlr on one channel of my current schematic, Pin 1 would go to chassis/signal-GND, Pin 2 would go to signal-IN, and Pin 3 would also go to chassis/signal-GND. Would this be the proper layout to provide phantom power to the mic, or would I need to add any components to Pin 3 entering the preamp, and if so, where does it terminate within the preamp. Sorry for my crappy wording. This is what I have so far (If XLR is used):
Current (linked) schematic:
  • Mic 1 > Preamp 1 > Chassis/GND [metal housing AND one pad connected to PCB ground plane]
  • Mic 2 > Preamp 2 > PCB signal input pad > caps/resistors/opAmp/etc [9v powered] > Signal Output
  • Mic 3 > *SEE Mic 1*
If anything needed to be added, I would keep Pin 1 as chassis and have a switch to toggle between the pad connecting to ground plane or what is needed to provide phantom power, so the layout would be like so:
  • Mic 1 > Preamp 1 > Chassis[metal housing]
  • Mic 3 > Preamp 3 > SWITCH A > PCB ground plane
  • > SWITCH B > ?(resistors and/or caps and/or battery +/-)>?(where to from here)[/INDENT]
The correct connections for a phantom powered mic circuit are:
XLR
pin 1 : chassis & phantom supply common.
pin 2 : signal & through a resistor to phantom supply hot.
pin 3 : signal & through a resistor to phantom supply hot.
The resistors are 6800 Ohms
While the XLR connector is not part of the audio circuit common, the best place to connect the circuit common to the chassis is near the input chassis jacks.
