first build - noob questions
can i ask what you mean about the 'high q'? and what this means?
The Q is, in short, the shape of the roll-off of the box with driver. The end Q of the box is (almost) always higher than the Q of the driver in free air. The spec for the driver is 0.89 so that is as low as you can get -- that would take an infinite size box (in practise you can get real close in a lot smaller box than that).
A box with Q = 0.707 is max flat, 0.5 is considered as low as you want to go, 1.0 as high as you really want. Anything higher than 0.707 starts to put a bump at the low end before it rolls off, not all that bad a thing with a driver like this that doesn't go very low anyway).
As you can see from the attached sim, not a lot of difference between 4 and 50 litre, and i added a sim for 2 litre which is not horrendous. You can see where the biggest box possible comment comes from. Keep in mind damping will increase the apparent box size (say max 20% in practice).
dave
I'm an engineer too 🙂
This is a deep subject. There's a lot to be said for something just sounding "right" but measurements and some sound (pun!) design knowledge will really back up your builds.
I like the fact that you've gone straight into the builds. Probably the opposite of me 😀
You'll find a lot of the answers to your questions on this forum. Keep an open mind.
Get a calibrated USB mic as you don't have to deal with your sound card calibration. The UMIK-1 from miniDSP or UMM-6 from Parts Express are both good. Download REW software and you are set. That is fantastic software and fully featured for free.
xrk971
I think it sounds great, it is completely balanced and isolated from any other object so it produces a unique sound that I really like. I thought it would struggle to produce any bass, but it holds its own just fine.
ewollowe
I am not the first person to make a dodecahedron, they are traditionally used as a omnidirectional point source for acoustics analysis. I have seen a few other about on the internet including a 3D printed version and one cast from concrete.
