Did You build a prototype?
Did you build a prototype and see what it sounded like with the
451 driver in it?
RCF now has the 551 version out with longer Xmax.
Of course it costs more and requires more power (slightly less efficient)
but will handle more power (ie: LabGruppen 10000Q or 20000Q).
Another driver that shows promise ($$$ wise) is the Celestion NTR21-5010JD.
Less Xmax, but almost half the cost of the RCF on Amazon.
451 driver in it?
Sad that all EPA's (and all you collaborators) design work didn't come to fruition in pics.
I think the design is VERY build-able and quite elegant.
I lost all my LABsubs to a permanent install and I need "road" subs
for this line array I have.
hi thereSad that all EPA's (and all you collaborators) design work didn't come to fruition in pics.
sad to say it's never been bild.🙁
the 551 sims good in the same cab.
regards erik
if it works well...............
I believe this is an arrayable solution to my problem. My problem is my line array is a quite serious box with high output (RCF TTL-55). Finding a sub to ground stack and keep up with it (30-120hz, worst case "driven really hard" scenario) is a task.
I had LABsubs that worked quite well in that passband, but went to a permanent install last year;(.
Time for a new design.
Can't do the RCF TTL-56 boxes. Can't utilize my existing amps and they're too much $$$$$ relative to what I can build.
If I can build 16 Labsubs, I can build 16 of these. The Unisaw calls...........
Plus we have a resource for 18mm 13ply locally.
Attached is my "final"? drawing or the build.
imagine 16 of those.that would be neat.
the pleminary 18sound 21lw2500 is also a good contender for the cab.
keep us posted 🙂
keep us posted 🙂
It will be a Spring project, I'm thinking.
As long as these trucks hold up.............
Only problem I had with the LABs was pole-piece heat and power compression
at EDM shows where the duty cycle got near 50%. It didn't help the amount of compression/limiting we had to run to minimize excursion damage on those drivers.
These 21" drivers seem to minimize those issues and this cab design has the magnet structure out there in the open air so they can radiate that heat.
I'll keep everybody posted on the results.
Thanks ever so much.
one of the disadvange's of neo magnet vs ferrit.
a huge coil helps also
18sound is the only one who quotes powercompression nr's.
i gues an rms limmiter is a must with those labs.
final
I think I'm to a point I can do a prototype in MDF from this drawing. Had to pull/push today to keep the "M" (expansion coefficient) constant in the radius areas. It "looks" right anyway. Sorry for the Imperial dimensions. That kind of dates me and where I'm from.😕 I'd be metric too if everything here was converted. Spring time before I can hit stride with this. Quite busy with the case building right now.
Thanks Midas M-32...............
expansion is not that critical ,anyway looks alright.
midas m-32 nice.
whe stil use an analog soundcraft 32-8-4 table.
(not me ,i gave up mixing few years ago because of hearing problems 🙁 )
midas m-32 nice.
Just stumbled on this thread. Very cool - great work and super generous contribution from Epa here. Looking forward to seeing it realized. What does 2.5 sheets of 18mm BB and the driver weigh? Also it is not clear is the final selected driver still the 21in RCF or is B&C 21 getting selected?
heavy..........
The sheets of 18mm baltic birch weigh 75# each. It will take just under 2.5 sheets per box depending on the bracing and how crazy you get with that since those can be the odd shaped parts. The box itself will weigh about 230#. Driver selection will add from that. The construction has to be air tight so 13ply is the most stable/dimensionally consistent material you can find. Use the Russian stuff, it has waterproof glue and takes a deck screw extremely well. The screws have to pull the panels flush and that takes a LOT of force.
All the Italian Neo drivers are pretty similar in weight/cone composition/and BL factor.
The price spread depends on the relationship with your supplier. These things are not flying off the shelves since 18's have ruled the market for so long and are still getting the job done.
The criterion for MY driver selection is:
over-excursion forgiveness (LabGruppen 20000Q's take few/no prisoners)
*sensitivity/power handling trade-off
*weight
*dealer support of the product
*price
The four top driver contenders for me are:
B&C 21SW152
RCF LF21N451
RCF LF21N551
18Sound 21NLW9600
they range in price from 600 to 900 bucks each.
So in theory, this box can be built using sweat equity for less than $1,000.00 each if you're resourceful.
*weight
*price
B&C 21SW152
RCF LF21N451
RCF LF21N551
18Sound 21NLW9600
fwiw
don't know if the 18sound 21lw2500 is already availeble
its sims very wel in this cab.
also i would pick the 21nlw 9000 over the 9600,same specs(x-max x-lim ,powercompression poweratings)
but sims much better.
availability
18 Sound isn't distributed too widely in the US. US Speaker and Loudspeakers Plus carry them but don't have many choices in their product range.
RCF and B&C have better availability and selection of drivers. They must market here more aggressively than 18 Sound does. That's a shame because 18 Sound makes beautiful drivers. My KV2 Audio wedges use all 18 Sound drivers in them and they sound VERY good and articulate.
Does the B&C simulate in this box well?
yes they both sim wel,a litle more sadeled responce due to lower re and le.ripple of + 3 db max
- Subwoofers
- R evenge C omes with F orce
