Yes, but it is not a big problem. I do not need a lot of unnecessary services which is the Squeezer. I know what I want to play, so I just need to navigate there and play. That is all.
So just a simplified user interface would be a solution?
Spotify on Daphile
I have DAPHILE running on a Gigabyte Intel Celeron N2807 system. Daphile Version 14.11-b280644-x86-44
FLACs from an installed SSD stream perfectly, and Pandora is functioning without issue via the mysqueezebox.com configuration.
However, the Triode Spotify Plugin isn't working. I can select the Spotify App and the selection list comes up:
Top 100
What's New
Library
Playlists
Radio
Recent Artists
Recent Albums
Recent Searches
Search
When I drill down to select an Artist or Album, a long wait ensues, followed by the error message:
Error reading headers: Server closed connection without sending any data back at /opt/mediaserver/CPAN/Net/HTTP/Methods.pm line 306.
...propagated at /opt/mediaserver/CPAN/Net/HTTP/NB.pm line 32.
I have Spotify configured correctly at mysqueezebox.com as far as I know.
Any ideas how I can fix this and make Spotify function normally?
Top 100
What's New
Library
Playlists
Radio
Recent Artists
Recent Albums
Recent Searches
Search
Compared to previous versions of October and November, the latest version that I am using the exact same system sounds very good, I would say even betterAny news on the sound of the new version?
my favorite version of September. I am really very happy.
Congratulations to Kimmo
How the hell sounds different something that should be identical?!
The human mind is a wonderful thing...
identical is just my system. The software is in constant development and change.How the hell sounds different something that should be identical?!
Previously I wrote that the versions of October and November were questionable in terms of listening.
Ignorance is bliss..
And faith trumps science...
Do not worry ... for you there is no difference...nothing problems
identical is just my system. The software is in constant development and change..
Constantly examine your faith..And faith trumps science...
to have too much faith in science is a mistake ...And faith trumps science...
Not only for me.. http://www.diyaudio.com/forums/pc-b...le-music-server-player-os-11.html#post3679365Do not worry ... for you there is no difference...nothing problems
You picked the wrong hobby.. in electronics everything is predictable and measurable..to have too much faith in science is a mistake ...
Kimmo has its respectable opinion ... you respect mine too.Not only for me.. http://www.diyaudio.com/forums/pc-b...le-music-server-player-os-11.html#post3679365
old story .... unfortunately things are not like that .... and I'm not wrong hobby.
Clearly even open source software can be subjected to audiophile voodoo.
Unfortunately there is no detailed information about versions of the packages included in daphile. Nevertheless, I very much doubt the audio path gets bit-imperfect between daphile versions. That would be a misconfiguration (basically only resampling being a candidate for possible difference in "sound") which most likely does not happen.
I register the changes in my perception and I put it in communion here ... then everyone remains in his opinion.Clearly even open source software can be subjected to audiophile voodoo.
Provide credible results of a positive blind listening test showing you can identify the differences just by your ears, and the perceptions will turn to a serious observation deserving further investigation for reasons of the difference. Until then your perception are... just your perceptions.
the blind test is somewhat questionable in the scientific substantiation and has no credibility. when I judge, I do it for myself, not to convince other people.Provide credible results of a positive blind listening test showing you can identify the differences just by your ears, and the perceptions will turn to a serious observation deserving further investigation for reasons of the difference. Until then your perception are... just your perceptions.
Please tell us more!
That is why you fail to convince us.
So I assume you don't have too much faith in the results of technology (such as computers, mobile phones, electricity, cars and modern medicine) either?
Technology (and that is what audio gear is) is not created by reading the sky and chicken entrails, but by applying scientific principles.
- PC Based
- Daphile - Audiophile Music Server & Player OS
