Yes, but it is not a big problem. I do not need a lot of unnecessary services which is the Squeezer. I know what I want to play, so I just need to navigate there and play. That is all.
So just a simplified user interface would be a solution?
Compared to previous versions of October and November, the latest version that I am using the exact same system sounds very good, I would say even betterAny news on the sound of the new version?
How the hell sounds different something that should be identical?!
identical is just my system. The software is in constant development and change.How the hell sounds different something that should be identical?!
Ignorance is bliss..
identical is just my system. The software is in constant development and change..
Constantly examine your faith..And faith trumps science...
to have too much faith in science is a mistake ...😉And faith trumps science...
Not only for me.. http://www.diyaudio.com/forums/pc-b...le-music-server-player-os-11.html#post3679365Do not worry ... for you there is no difference...nothing problems😀
You picked the wrong hobby.. in electronics everything is predictable and measurable..to have too much faith in science is a mistake ...😉
Kimmo has its respectable opinion ... you respect mine too.Not only for me.. http://www.diyaudio.com/forums/pc-b...le-music-server-player-os-11.html#post3679365
I register the changes in my perception and I put it in communion here ... then everyone remains in his opinion.😉Clearly even open source software can be subjected to audiophile voodoo.
Unfortunately there is no detailed information about versions of the packages included in daphile. Nevertheless, I very much doubt the audio path gets bit-imperfect between daphile versions. That would be a misconfiguration (basically only resampling being a candidate for possible difference in "sound") which most likely does not happen.
the blind test is somewhat questionable in the scientific substantiation and has no credibility. when I judge, I do it for myself, not to convince other people.Provide credible results of a positive blind listening test showing you can identify the differences just by your ears, and the perceptions will turn to a serious observation deserving further investigation for reasons of the difference. Until then your perception are... just your perceptions.
