What is your intendet operation point for the 2sk82?
I guess 400-500mA and 90-100V. You are good here whit 80-100R load.
nice to have someone who understand you sometimes 🙂
looking at the blue load lines pic at 90/100V voltage it seems that with 10V change we have near 800ma variation. so let say that we have 12/13ohm resistance here..
or i'm totally wrong 😀
ultrapath cap
hi folks, i have made a little change on my ironamp swapping the gate bias and just put a 56R source resistor . as some SET tube amp i 'm using the " ultrapath" capacitor between the source and the B+ and no bypass source resistor. is there a " magic" value or a calculator for this ultra path cap ? ( for the moment i use a 100uf MKP) and i feel i 'm missing some low end .
easiest to try
put some electrolyt in parallel for test
if bass is better , replace with solid cap
easiest to try
sometimes i wonder why i'm so stupid.. than i forget 😀
last bullet for the year.. i need some gain with my ironamp , i have now mine running with RC input instead of transformer with -20V bias on the gate. my plan to get some gain is to use this -20V to power a 2SJ74 direct coupled to the 2SK82 . what will be the `jfet source resistor value needed with this voltage?
i have done it with the TL431 bias of the CSX1 but it not worked , it sucks too much current and i can't have 20V anymore on the 2SK82 so the fuse blow .. not the VFET ..
anyway i'm sure it"s a bad idea 😀
Would this heatsink do for my IronAmp?
NV115-1 AAVID THERMALLOY Natural Convection Heat Sinks | 10WX1029 | Newark element14 Canada
Dan 😛
Dan 😛
I'm almost done my CSX1 and now I'm intrigued with this amp! 😱
Dan
i have build both and prefer the ironamp ( with some tweaks 🙂 ) the 2SK82 will dissipate 33wat so not a big deal for a decent heatsink 🙂
Which tweaks?
Some of my thoughts on parts.
Antek Toroids for the transformers Transformers - AnTek Products Corp
I have some spare Peter Daniel Rectifier boards
http://www.diyaudio.com/forums/swap-meet/99351-wtb-f4-pcb-boards-24.html#post1237660
I have some spare 159ZL's sitting around. Would they be suitable?
http://www.hammondmfg.com/pdf/5c0032.pdf
I was think of some sort of RC circuit RC time constant / voltage calcultor to delay the relay powering B+ picking up.
And so on and so on......................
Dan 🙂
Perhaps the most challenging part of building this IronAmp would be finding suitable power supply capacitors?
2X NEW Kendeil 22000uF 100V K01 Caps Krell KSA50 Naim Hicap Leach AMP | eBay
Dan
Dan
Dan![]()
Sorry, referring to Michael's schematic these would be a better choice,
2pcs NEW Kendeil 4700uF 100V K05 105C HI END Caps FOR Audio QUAD303 Naim AMP | eBay
And,
10pcs Siemens B41070 B9477 T 470uF 100V HI END Audio Capacitors FOR Audio | eBay
Dan 😱
i went to the CLC road , with 2000uF 4H choke and 400uf MKP expensive but the last cap make the sound 🙂
- Ironamp Video Posted
