How do you store your Resistors and small Capacitors?
All,
This is my question: How do you store your Resistors and small Capacitors?
This is my (and your?) problem: I do own many parts, most small, that need to be stored. Using compartmented small boxes is not ideal (for instance 2 decades of e192 resistors is about a 1000 compartments).
What to do? So I thought I ask my fellow resistor addicts :)
Frans.
Moderator
Joined 2011
How do you store your Resistors and small Capacitors? This is my (and your?) problem: I do own many parts, most small, that need to be stored.
I'd suggest very small plastic reclosable bags with a paper ID label enclosed. Having loose parts in bins allows parts to migrate.
You can group the bags by decade of value and bin them. 1 1/2 x 2" 2 Mil Reclosable Bags S-220 - Uline
How about envelopes, in a map, Wim(P) ?
Not my idea, Mr Wurcer or Mr Martin's I think.
(for 100-up a value, I still use compartment boxes, with added diy divisions. With >20k resistors of various brands not much choice. Some are kept in round plastic containers, HEMA/Xenos. Empty perfume bottles in the right shape, hotel shampoo ones are a favorite, also an avid film roll box collector)
The (my) problem with these is break-down's, they tend to be real bad quality some of these bags break down (the zip mechanism) after only 2 or 3 times usage. Also they sag and this makes a mess of the box where they are stored. maybe small boxes will do. Any way I will see if I can get good sturdy bags to be used.
I purchase the Vishay CMF-55 and CMF-60 resistors by the box, just label the end of the box. Other components are in polyethylene compartmented cabinets which are very inexpensive at Home Depot, or Bed n Bath stores.
Paper envelopes, that's what we used in the old day's (ice ages) the problem is, they deteriorate very fast, you can not see what is in them (there may be different sizes (wattages) in each). For E12 (and I have a lot of those) the compartmented drawers are fine, but this is not possible for E96 and E192 (as I am using mostly nowadays).
Most of the resistors that I use are CMF55 or RN55 and 60's like you do. But most are delivered in non reclose-able bags, some in boxes, come bags are transparent and others not. I would like a more organized, and uniform, easily accessible storage system.
One problem (I see :)) is that one only owns a small part of the range. At the moment that you get a new value you want to insert it at it's proper place, the envelopes/bags do support this. Coming to the conclusion that I want small transparent close-able boxes for the price of plastic bags.
Further to Jacco's idea -- there are polyethylene sleeves in which photo-transparencies are stored. These fit in a 3-ring binder. I use the 2 1/4 x 2 1/4 (6x6cm) left over from my Rollei days for storage of precision resistors.
Yes, but the access ability is so-so, you can not 'insert' new values and they break easily. I do that for my ceramic capacitors and I do not like it :( I even when to far to build my own 'books' for that (I will post a picture).
Self made capacitor 'album'
Reactions: 1 user
I recycled clear plastic packaging, the kind people cuss trying to get open. Cut into rectangles slightly smaller than the bag, it makes a thin but sturdy structure, and can double as a divider so you don't have to have a new bag for those eg half-dozen 2-ohm flameproof resistors you overbought for a past project.
I like that, plastic bags with an 'sturdier' inside :)
Some 'Ice age' pictures can be found here :)
https://www.flickr.com/search/?w=17267211@N05&q=stuut
