How do you store your Resistors and small Capacitors?
Look here... maybe a good way to keep our parts albums: https://www.sparkfun.com/products/10654
PS: Maybe someone have been working in reichelt or mouser.... these guys could provide us with good tips
I do not like the albums, or you need to allocate 192 envelopes for E192 or you have to shift them around (both not very attractive I think). Also, I think they do not hold many resistors, my stock will be varying from a few per value up to maybe a hundred or so. As said before I want a system that easily handles 'insertion' of new values (like the zip-bags solution) but then a bit more neat... (may I am to much of an control freak).
I collected match boxes and glued them together in 12 x 5 matrix for E12 sorting. E24 went to the closest drawer. Values below 10R and above 1M were stored separately. But this was just for experimental and surplus resistors, since I bought just what I needed.
From all this, I think using boxes is the best.
Like here: http://www.diyaudio.com/forums/atta...-your-resistors-small-capacitors-storage1.jpg
I do not like to use the boxes as supplied with the goods, I would like to build a cabinet that holds the boxes (in a organized way) and I would like a to have a independent source for the boxes.
It seems to me than folding carton/thick-paper boxes as used for medicines are fine, they can be bought in different sizes as stencils.
Like here: Catalogus | Pharma-Pack
Does any one has a good idea for a cheep source? The box sizes I would prefer are:
100mm(4") x 75mm(3") x 50mm(2")
100mm(4") x 75mm(3") x 25mm(1")
100mm(4") x 75mm(3") x 12mm(1/2")
Any input on that?
Maybe we can organize a group buy.
Maybe it is something for the diyaudio.com store.
I place the resistors in polyethylene bags, separate them with an index card and place them in cardboard sleeves used by distributors.
My precision resistor book, with the 6x6cm slide carriers -- just buy one of the kits from Digikey and place them in the folders. This is a huge time saver.
Many of my components go in standard 11 * 22 cm envelopes I collect from postal mail and which I put them in classified order in Ikea sets of 24 cm wide drawers.
On the top left corner of the envelopes, I write the kind of components in an abbreviated form : Tr, Di, R, Rpre, C, Cpré, Fus, Reg, Z, etc...
In the middle of the envelope, I write the main values , types, and as many details on data as I find necessary.
Some envelopes may contain only one component with rare specifications or a pair of previously hand matched components.
This system is fast, handy, powerful and economic, and except for the drawers, comes for free.
Good question, since i have the same problem and the larger values i just try to keep with the same value in a box with variable size space and which opens from above and put there a label on. Resistors in a plastic bag with the value on it and in standing unit with a number on each container which in excel, easily can switch from content, since every container has a number. Small caps is the harvest part, since there's no way to keep value and brand etc. seperate for a long time: so i put them together(standard once) and the high grade once i keep away from the normal series and order them nicely in by brand in a seperate box .
Well , i count them and then they gothether, low cap mid cap highcap. But i try to keep a record of the stock i have of them in excel. same with good resistors etc and they go in the antistatisch bags. But it's hard, only i don't know any systems then the standard once, every electrostore has.
Greets richard
There is another issue regarding parts storage.... keeping track of what you have and where it is stored.
I keep a database of resistors, caps and semis but the trouble is to keep it updated.... everytime I use something I need to update the database.
Actually I have some disorder here and sometimes I know I have parts "because I remember" but can not find them, so I keep buying.... dreadfull situation.
I store most of my discrete components like resistors and capacitors in plastic bags in clear plastic shoe boxes. I have a lot of components but a very very small shop. I find this about the most efficient use of space and still easy to find what I need.
The bags in the photo are a very high quality thick antistatic bag which I bought online in bulk. There were quite inexpensive. I can't remember where exactly I got them as I bought them some years ago. For larger components I just use good quality ziplock bags from the supermarket. The shoe boxes are available at walmart and canadian tire here in Canada.
You do know I'm a software professional 🙂
