100W Ultimate Fidelity Amplifier
So I am done with this amp.. I used preamp and transformer from original.. for premap was used dual PSU with LM337 and 317 ... I need solve problem with very little hum.. any idea with grounding , because there is no ground wire.. (two wires only for 220V)
short movie:
APEX A14 - YouTube
There is no earth wire (earth and ground is different), you need star ground for preamp psu ground and amp psu ground... nice work anyway
yes i Know...I usualy using this schematic:
Do not connect the PSU "charging circuit" through the main audio ground. NEVER !!!!
The AC twisted triplet from secondaries MUST go to the first smoothing capacitors.
The DC twisted triplet from the LAST smoothing capacitors MUST go to the amplifier.
This applies to BOTH PSUs.
3648 is correct. I note there is NO CONNECTION between Speaker Return and Signal Return
