100W Ultimate Fidelity Amplifier
138x99mm,with single and dual op-amp,Zobel network,PRO circuit to suite to NE555 protection,CLIP indication...
  • A23.zip
    A23.zip
Here the very first design for the A9. A little bit unusual format, but enough for a first test 🙄. Could be a little flat amplifier.
Not tested - coming weekend. Notes gladly welcome.
regards Olaf
There is mistake on your pcb: base MPSA92 must be conect to colector BC550 not to base... you can connect SGND to PGND (by mistake note as OUT on your pcb)
I already done with one chanel ...very easy to build, just need set bias and play.. picture show sine at 100khz, square at 10khz and 20 khz...
short video...
Apex A14 - YouTube
