First try beginning with the input stage...
The sound from A17 is so impressive that I could not do otherwise than start the next test 🙂.
But need some more time.
regards Olaf
Olaf try A9 first...
Use A23 schematic from post #3558
That was anyway on my list 😉.
I will try both.
regards Olaf
I will try both.
regards Olaf
Thank you,
Any reply to this ??? Please do reply,Also whats the best way to set the bias ?
Regards.
Btw in your views,which sounds better the 5200 version or 15003 ??
Regarding the Transformer,is 45-0-45V 5A (450VA) will do or should I go for 8A (720VA) ?? I need order them so asking,I want the best and Optimal so kindly suggest the same.
Also what bout the Slew rate of this ?? and Max Current ( for transient loads) ?
Regards.
Regards.
Use MJ15003/4 with 720VA transformer,
Thank you Mr.Mile ! What bout the Bias ? Whats the best Bias value to be set ??? Can I bias it bit high to get a class A like characteristics (for the first few watts ) ??
Regards.
Regards.
Regards.
Start with 30mA...
a lot of help from Olaf´s earlier works and this is what i draw,it should be checked and compared with schematics:
Nice work, but there is mistakes on your pcb...
here it is... : if someone else finds anythig more please let me know...
Nice work, you can add zobel network (4R7, 100nF) on pcb,
Much success with the A23, great layout - I'm very curious about the sound 🙂.
regards Olaf
- 100W Ultimate Fidelity Amplifier
