100W Ultimate Fidelity Amplifier
A23
First try beginning with the input stage...
The sound from A17 is so impressive that I could not do otherwise than start the next test 🙂.
But need some more time.
regards Olaf
Btw in your views,which sounds better the 5200 version or 15003 ??
Regarding the Transformer,is 45-0-45V 5A (450VA) will do or should I go for 8A (720VA) ?? I need order them so asking,I want the best and Optimal so kindly suggest the same.
Also what bout the Slew rate of this ?? and Max Current ( for transient loads) ?
Any reply to this ??? Please do reply,Also whats the best way to set the bias ?
Regards.
A9
Here the very first design for the A9. A little bit unusual format, but enough for a first test 🙄. Could be a little flat amplifier.
Not tested - coming weekend. Notes gladly welcome.
regards Olaf
