Ultra-high performance, yet rather simple - hybrid and more!
Hi Valery,
I started populating the IPS today. I have some questions.
I see two separate inputs. What are their purposes?
Why are there two 2.2uF input caps? Would one 4.7uF work?
Is the trimmer necessary since there is a servo?
What do schotty diodes do that standard diodes don't?
Thanks, Terry
Hi Terry,
Ok, answering one by one 🙂
- Two inputs - one is DC-decoupled (via the cap), the other one is direct - DC-coupled. Just to have both options available.
- Two 2.2uF caps - one 4.7uF will be fine, it was just difficult for me to find the one of appropriate size.
- Trimmer - not mandatory, can be jumpered. You're right, DC offset is controlled by servo, the trimmer potentially allows to set the best possible local balance for the input LTP for the minimum distortion. However, you need a THD meter or a good spectrum analyzer to see where the minimum is, also, the influence if rather subtle.
So, all three points - not mandatory 🙂
Valery
Those Schottky diodes - they are faster and they have lower voltage drop, than the normal ones. They limit LTP's maximum differential swing, allowing even better (softer) clipping, then "super VAS" normally offers.
I have checked in simulator - 1N4148 will work there just fine. Again - very subtle difference 🙂
Hi Valery ,have you any of this pcb for selling?
Hi Valery,
Can you produce a components view that has only the part numbers and not the values? Some of them overlap on the screen print and make it hard to read. It would make locating the parts much easier.
Thanks, Terry
Sure - no problem.
Sorry, I was too lazy for aligning them properly on such a "busy" board 🙂
Promise to improve in the future 😉
Sorry I misread that. Thought he was asking if they needed to be on a heatsink.
Thanks Valery. I'm not sure I will have enough boards now. I may be sending them all out. If the interest keeps up I may have to order some more if that's OK with you.
