How to build a 21st century protection board
Krisfr, Jeff - good list of functions, all of them are doable.
Simply depends on how far (deep, high) we want to go (dive, fly) 😀
I'm ready to support development in any area. I propose not initiating a super-duper-mega project, trying to build an inter-galactic spaceship 🙂p), but doing it gradually. We just need to arrange the hardware in a way that we will be able to move ahead without modifying it (at least for some time).
Attached is a hi-res image of the schematic (don't forget to press "eXpand" cross at the bottom left corner as soon as it opens).
Valery
P.S. I've got some material in microcontroller-controlled biasing - AES paper and the document Andrew (Bonsai) made available some time ago. Both are very good as a starting point for moving ahead...
It would likely be easy to adapt 2 wire sensors to your existing circuit as well. I want to fire up a heat gun and test the circuit, Just curious how long I would be heating. I think you have the pin numbers marked incorrectly on those temp sensor transistors in the schematic.
Umm... not sure I see what you mean 🙂
They are connected as "diodes". Emitter goes to the ground, collector and base together go to comparator input...
another control board here
I have a control board which a friend of mine developed for me. it combines fan speed control/soft start/speaker protection. it uses PIC16F819 controller (running PICbasic). fan speed is PWM controlled based on the higher of the two temperatures read (each on one channel heatsink). the temperatures are digitally read from DS18B20 temp sensors over one wire interface. the control allows for a faster warm up of classA amp since the fan is off until desired threshold temp has been reached. the PIC was chosen off the shelf and could not make use of the fan speed feedback, so the control is solely temp based.
amp on/soft start is on momentary push button and PIC delaying the second relay on PS rails.
for the speaker protection analog comparators and ICs generate DC offset alarm on which an interrupt routine in the PIC trips relays at amp outputs. this is the only part I have not tested with the real amp/music, since we included an adjust pot for both the DC trigger level (targeting 1V+-), and also one for a filter corner frequency. setting the filter so that it does not trip on loud bass, yet it is quick enough on amp failure is the tricky part which calls for a lot of fiddling and fine tuning (and I have not had the time).
there are three LEDs, for amp on, fan on, and one signalling the failure mode (overheat/Dc offset). I spent many nights with my friend troublshooting the code since there are many issues when coding at low level e.g. temp sensor not reading, or a cycle is too fast and a value is missed, etc. etc.).
I have two boards on which we fixed all the mistakes, and will need to order one more (which makes that single board very expensive). if you develop something i could use I might be interested. Otherwise i will publish mine (no secrets there) and look for anybody willing to share in the cost of my next order.
