It seems that Profusion will get connector kits in september.
Mine is from conrad.fr. I use two x 6 pins connectors, one for modulation and the other one for led on/off status.
I have not all the control functions, but the amp works well like that.
Very good quality sound, deep bass and sweet treble...
weird as ive seen exactly contrary opinion. most people who heard both hypex and anaview seem to prefer anaview...Ok. Excellent Patrik. I have tried the ALC1000 as fullrange just briefly. I normally use Hypex Ncore for that. Seemed to be quite a difference from the little I tested but that was expected too considering the price difference.
But I hear you might have contender for Ncore quite soon. 🙂
will likely try soon a anaview module based amp and report.
Which anaview, ALC or AMS?
There's a group-buy ongoing at swedish hififorum.nu on the AMS module - roughly 20 builders will hopefully be able to have opinions on this module within a month or two.
The ones who have heard it are intrigued by its sonic performance.
I'm eager to receive mine
/P
/P
Well, that's not ALC1000 which I have compared to Ncore, is it?the new module ams I think
Ncore is way better and more transparent and with lower audible distortion then ALC1000. No comparison. For the lower frequencies (I have compared them below 120 Hz), they are equal in my ears. I have also tried both in an active system from 500 Hz to 80 Hz. I was a bit surprised I easily heard a difference here to, in favor of Ncore.
kkWell, that's not ALC1000 which I have compared to Ncore, is it?
will you try the anaview new module?
if so, please share your comments!!!!
I'm planning to buy the new AMS1000 but not AMS0100. AMS1000 doesn't seem to measure as well as AMS0100 and is most likely primarily a bass amplifier but with ok sound quality of other applications.
AMS0100 doesn't have enough power. Most likely though more AMS amps are coming.
- Class D
- Abletec ALC1000 any experience?
