All,
I would certainly appreciate a good review of the schematics/layout/ideas that are posted so far.
Latest schematics attached. I'll post a picture of the current layout here later today.
Delete C34.
Delete C34.
Can-do. Can I ask you why you would delete this?
I assume I would also need to delete all the bypass to VGND caps that I added to each op-amp (C26/C27/C28/C29/C30/C31/C32/C33/C34/C35).
Should I just have bypass caps from VCC to GND on the op-amps (and not VCC-VGND/VGND-GND)?
Thanks for the help!
You want Vcc/2 (as it is commonly labeled) to be AC referenced to GND, not AC referenced to a capacitive divider resulting in half of any and all noise on the supply lines.
Makes sense?
Makes sense?
Makes sense?
Makes sense - so I should flip C26/C28/C30/C32/C34 from being referenced to VGND and change it to normal GND if I want to keep the voltage bypass on the op-amps.
Should I delete C27/C29/C31/C33/C35? Perhaps I should just keep one or two in order to maintain bypass on VGND on the various portions of the board... Thanks again for the help!
Also, I've seen arguments for having the series resistor in the virtual ground generator (R21) in front of and behind the feedback. Currently, I have the feedback listed as AFTER the series resistor because I was thinking that the op-amp would compensate for any voltage droop occurring across the series resistor. Should I change this?
This should be moved to Analog line Level:
Analog Line Level - diyAudio
No further comments on this thread.
My apologies to TPA3116.
Doug
Fellows maybe you may like to use battery to power the 3116 instead of PSU or Linear PS. I use 4*12 Vdc battery connected in series and parallel to give me 24Vdc. I can play music continuously for more than 4-5 hours without the need to charge them in between times. I use them on my TK2050 and will test them on my latest purchase, a 3116.
Give it a try and you would be pleasantly surprise.
What Ah rating for 4-5 Hours ?
I've juste received two sure TPA3116 boards.
The stock board sound pretty good 🙂 .
As I remember much better than the YJ 2.0 red board, I will try this board again.
I will try changing the main power caps to OSCON type.
Concerning the snubbers mod, maybe I'm wrong, but I've read that this mod is already part of the design ?
PS : As writen before, don't' forget to swap +and - on out1 on this board !
Trying to get the SMT 10R .4 watt thin film resistor for ybdz subber mod, mousser nor digikey has them, will thin film work? Thanks.
The 330uF/25V Panasonic SEPF OSCON caps have been working very well in my Sure TPA3116 amp. This amp includes the bootstrap cap snubber circuit, so aside from the OSCON cap upgrade, this amp is almost plug and play-ready. KJA 2013 says a higher power supply voltage >14VDC seems to bring the most out of these Sure TPA3116 amps.
Note that I took the 4x 2,200uF/25V Panasonic FM off-board power supply caps out. This amp doesn't need them.
The Sure amp in stock form is better than the YJ amp in stock form. I'm still in the middle of evaluating mods, so I can't say which is better in modded form.
Sure TPA3116 amp
Can by adding any of these below components give more fidelity to the Sure TPA3116 amp ?
CineMag CMLI-15/15B input transformer
10uH Coilcraft SER2915L-103KL inductors
Vishay-Dale RN55 resistors
KHOZMO ACOUSTICS 48 position 50k "stereo" balanced Stepped Ladder Attenuator with upgrade 4x (CAR-455) - 50K 0.4W Charcroft Z-Foil Resistor
http://www.partsconnexion.com/conrtols_attenuator_khozmo.html
http://www.hificollective.co.uk/catalog/car455-charcroft-zfoil-resistor-p-9867.html
Can You, plzzz, compare Sure and YJ red board and write about it. Sure vs. Oscon Sure...
Can You take a bottom picture?Note that I took the 4x 2,200uF/25V Panasonic FM off-board power supply caps out. This amp doesn't need them.
4x 2,200uF parallel, right?
Please, may you comment what they claim:
Comprehensive click-and-pop reduction circuitry minimizes noise coming into and out of shutdown or mute.
Does it really work?
Ty
- Class D
- TPA3116D2 Amp
