Class D output filter design
Get a copy of TINA spice program from TI and just simulate it - very easy to use, just draw the circuit, click on components to set value, then run AC frequency response analysis. Can use straight resistive load or a lumped element model of the driver for most accurate results of the filter - tuned to your specific driver.
SPICE-Based Analog Simulation Program - TINA-TI - TI Software Folder
For example, here is the filter for the TPA3116D2:
Additionally, other interesting output filter design criteria is to move inductor value towards the inductance needed to achieve resonant switching when the amplifier is idle, this saves idle power.
Fsw = idle freq (hz)
Vrails = +/-rail voltage (V)
C = capacitance attached to the switching node (FET + snubbers) (F)
t = dead time (s) (minimum reliably allowed by circuit)
Current needed to charge C from -Vrail to +Vrail in t :
I = 2*Vrail*C/t
Ideal inductor value that would achieve this peak current just before switching node toggles:
L = Vrail*(.25/Fsw)/I
Gate resistors have to be chosen so that gate controlled turn-on dV/dt in switching node is not faster than the dV/dt created by the resonant current in the inductor. This suppresses switching losses for output currents from -I to +I.
I is also the peak output current that the amplifier will do before dead time distortion starts to show up. Higher I makes the low-power lowest-distortion zone wider.
I = 2*Vrail*C/t
Eva is that really you ? oh my word. where have you been ? soul searching? welcome back ! 🙂
Maybe , if the inductor is included in the feedback loop. But when not the criteria is a flat frequency response , look at Iraudamp7
