class AB 10.000W RMS @0.5R - 20.000W rms bridged
More than 5Kw output and less than 0.09% distortion from 20 hz to 20 khz, good for low freq. and lower mid as distortion less than 0.037%at up to 1khz, Load showing more than 10 kw at 0.5 ohm, more than 5 kw at 1ohm load, with 28 pair in output will deliver more than 5 KW.continuous . Designed by Vedmitra.
I have a few questions- When will the PCB's be made available? What is the idle consumption? What are the -3dB points? What is the harmonic and intermodulation spectrum like at different frequencies and various power levels? How stable is it into reactive loads? What kind of reactive load does this design place on the preamp upstream? Thanks ya'll.
This ciruit looks woking well by simulation and physical values requires application. pcb of the driver shall be fine and could be your contribution , also enough for realizing if you mean that the pcb cannot handlle the current. Safety operation requires adding power factor correctors and also.
İs Haarlem ver vanaf Dieren,; daar ben ik geboren..
Haarlem is on the other side of the country from Dieren, but it's a small country... I've been in Dieren a few times when I worked on a filter for pacemakers for Vitatron (which company doesn't exist anymore, according to Wikipedia).
To get back on topic: I know from experience that it is very easy to get permanent tinnitus, so please be very careful with this amplifier!
