Amanero Isolator/Reclocker GB
For NDK and Crystek, 50 pcs minimum quantity per value or manufacturer?
Unit price indicated is for batch of 50pcs. Manufacturers may not commit to supply lower quantity. Plan is to take the popular model on the list and advise further.
GB is open to all if these clocks are suitable for your other projects -not just for use with S03
Hi All,
... I have a question that I hope one of you (maybe Acko?) can shed some light on:
I'm currently testing the AKL-AMN-S02 isolator PCB with the Amanero combo384 and an XO board with a 24.576 MHz oscillator and it seems to work: When the Amanero get's the external 24.576 MHz clock (RCK) there's a bitclock and LRCK output from it.
I just wonder how I get this RCK (XO clock) to go back to the Amanero board while maintaining both MCLK and ground isolation?
The Si844X & 8221 series of isolators that are used on the board have some versions that are bidirectional on two pins on both sides of the isolation, however, as far as I can see this possibility has not been implemented on the S02 board ... ? When I measure the signal on either of the "side 2" pins of the isolators there's no RCK signal ... Is this because it is not feasible to lead the RCK back to the Amanero board - or did I somehow miss something?
I'd appreciate if one of you have experience with this ...
Cheers ;-)
Jesper
Any light we could gather 50 pcs to make the group buy happens? 😛
I think it would be a good idea to post a new separate thread for this in the group buy forum, to get more people interested, and the GB rolling.
making enquiries already, for a limited number of samples to get going.
This is already a GB thread and closely related to the re-clocker application. Not sure how else we can get more to be interested?
If you have samples to start with it is great. I was thinking that a new thread for only clocks could make interest from people that does have other reclockers like ians fifo and so on. Since there havent been any source for 9x.xxMhz clocks except sil (which is not the best) as far as i know.
Anyway, as long as you are certain we will reach the amount - then no hurry for me, since i wont neehd them right now.
Guys, I'm still on the fence. My primary requirement is get some clocks for the up and coming BBB Cape . Can anybody shed some light on if these clocks would work? If so more people eagerly anticipating the BBB Cape might be intrested in these clocks as well..
Meant to match the S03 boards. May be suitable for other applications but please check carefully if they suit. Sorry, no support available if used elsewhere.
After a very long hiatus, finally ready to purchase components and populate my S03 board. A bit fuzzy on the details after so long. Chain is Combo384 + S03 + Otto-II + Buffalo-II with 100MHz clock. I should be looking at CCHD957 @ 45.x/49.xMHz, right?
BK
It will take ~2-4wks to firm up everything for pricing and availability. I will be a fully populated board. "Batteries not included ..."
Yes, isolated I2C will be good but prefer to be on the UPS cape rather than going through the S03 board. So no changes to the S03 board
Thanks for your input 🙂
Acko,
Any updates on the BBB UPS cape? Very interested in this, especially as a way to keep from killing BBB's via improper shutdown.
TIA!
Greg in Mississippi
BK
For BUFF-II/IIIs with its own 100MHz clock in asynchronous mode it is best to use just a single CCHD 575 100MHz XO for the S03 board.
