Yes, I see what you mean about the cost Erik. Duelund Cast DC Silver - over 400£...
I'll save that upgrade to be the last one. The Mundorf will do for now 🙂
Thanks Erik. 🙂
Is 0.01uf enough? Tibi recommends 0.1uF...
I do not know how far the MKII differs...
Just try them both and decide for yourself...😉
Thanks Erik. 🙂
Turbon,
Shiga MKII wil work fine with 0.01uF, however I recommend 0.1uF to be on the safe part. With 0.01uF sound is wonderful but thing become a little unstable on low reflection, low quality CD-RW's.
On other hand compared with few other 0.01uF caps (Hovland, Multicap, Clarity) 0.1uF Mundorf EVO silver-gold-oil is a clear winner. It is fast, detailed, dynamic and very musical presenting full instrument body.
To my ears 0.1uF Copper Cast-PIO Duelund is a little slower, while extremely musical, but speed impact is somehow lost.
The silver Cast-PIO Duelund may be a clear winner, but so far the best price compromise is Mundorf EVO SGO.
Regrads,
Tibi
I have good experience of using the SIO part in my phonoamp. Very clear and musical.
I will probably test rhopoint miniohms at R48/49.
Turbon,
Regrads,
Tibi
Unstable....
I cannot confirm nor deny this...since I only play original cds. 😀
I have quite a selection (3000 originals) and the ones I played so far ( last 6 years) were all played without misreadings, skipping etc.
Making use of 0.01 uF on C906 the last 5000 hours plus....
On the other hand who wants to listen to low quality CD-RW's with a transport like that......but that is another matter 😉
Edit...I am lying. There was one that was Oceana from Till Brunner...that reminds me to buy a new one tonight....lol...
"On the other hand who wants to listen to low quality CD-RW's with a transport like that......but that is another matter"
There is some logic in your writing Erik 🙂
Unstable....
Erik,
From my point of view Shiga MKII must read any CD, good or bad, otherwise I get angry DIY-ers ... 😉
CD-RW are the worst CD's you can use for music reproduction. Their reflection is only 10-25% from a good quality pressed CD. Therefore Shiga will increase gain in order to read CD-RW. Increasing gain by an amount ~10 may lead to oscillations and tracking loss when C8/C906 is very low. Due very good PCB layout, Shiga MKII have even a higher gain and remain stable on any CD-RW. This will not happen with original JVC.
A CD-R, depending on his quality may have between 40% to 70% reflection, compared with a pressed CD.
I also consider that is a sacrilege to use Shiga on copied CD's.
Due poor reflection indices a copied CD, CD-R or CD-RW, will never sound like an original CD.
Tibi
Good information. I will probably test with different values to see which I like best. I don't have any cd-rw but a bunch of cd-r's that I wan't to be able to use.
Did you measure minireg's output before mounting them ? 😉
Whatever clock you use, miniregs will work.
Tibi
How to measure before mounting ? there is no voltage ? 😕
You have few drawings here vicol audio : Low noise LDO mini regulator
Apply a voltage of 6-9V between IN and GND and you should get 5V at OUT and GND.
Tibi
Tibi
Found all my minireg without led and two R.
LED draw extra current and was removed.
Pcb can accommodate fixed and adjustable regulator chip, depending on this there is one resistor more or less.
See construction here http://www.diyaudio.com/forums/digi...mkii-black-builders-thread-2.html#post3920952
Tibi
Tibi
Always SMD parts first.
And now ready to move further with main board modifications.
TBC.
Tibi
Hi Tibi ,
when use LT1086 ,R50 need to use ,right ?
Hi Tibi ,
Only if you use a LT1086ADJ.
If your LT1086 is a fixed voltage, than you are on the wrong side, as there is no fixed 8V one. To be sure, make a picture of the chip and post here.
Tibi
Tibi
ok ,if i use LT1086 ,what is needed ?
http://www.diyaudio.com/forums/digi...e-mkii-black-builders-thread.html#post3918572
Tibi
Turbon,
A more tolerant CD puck is on the way to you. This was machined on the lowest tolerance 5.95mm as per datasheet http://vicol-audio.ro/docs/DA11VZ.pdf
Your feedback here is mandatory. 😉
Tibi
Tibi
- Digital Source
- Shigaclone MKII Black - The builders Thread
