F5Turbo Illustrated Build Guide
In my F5T V3 I use a transformer that, according to other members here on diyAudio, will give +/- 41 V DC. This higher than what Nelson describe(+/-32 V DC).With higher power than +/-32 V DC, it has been discussed to change some resistors values. It is the value of R5/6 and R25/26/ R28 that have been discussed. Voltage at the drains of the jfets should be in the range of 12 to 15 V. Using the cascoding formula and 10k + 4.75 k gives this results: 41V/14.75x4.75=13.2V. This is well within the recommded value of 12-15 V. So with my transformer, there is no reason to change the value of R25/26/28, right?? What about R5/6?? Other changes to be done??
Eivind Stillingen
Hi all,
Sorry for asking probably stupid question, but I confused a bit.
From PCB description page I do see 1 PCB kit with 6 bards. 3 boards (1 main and 2 outputs) are for a 1 channel. Now, and in order to create v3 with 100W output, we need to use mono-block architecture.
That is my question: does 3 boards (half kit - 1 main and 2 outputs) are for 1 channel with 100W output?
If yes, and that is what confusing me, 2 output board can accommodate 2 transistors and 2 diodes. I do see 8 transistor and 8 diodes per channel on schematics. So, it is half of output cascades can be populated on 2 output boards per channel.
Can you please clarify.
Thank you.
Alex
Now it is clear.
Oops, I already purchased one kit....:(.
Should wait for your answer.
Thank you.
This is the consent of monoblocks for 100W setup....
The boards you have featured say Version 2.2 while the store boards presently available are V3.0. What is the difference and is a clear picture of the V3.0 boards posted somewhere?
Where are C3 and C4 as on the schematic? Is it labelled C1 on the output boards?
Can I fit a 14AWG stranded wire in the OP holes and G holes on the FE and output boards? Or perhaps you can say what the hole size is?
Thanks.
