Slewmaster - CFA vs. VFA "Rumble"
and make again loopback measurement, compare this with "clear" loopback. Results should remain unchanged, it should be the same picture as above. According your pictures, connecting input cable shield (so creating ground loop) worsen results more than one order of magnitude, for the same amp.
Do you mean something like this?
Hi Thimios,
Which version of BV's mod did you do? I am trying to get the one attached to work and it won't. Today I built another board to see if maybe I had done something wrong with the first one and still it won't play nice. Would you or anyone have a look at the board and see if it looks like it follows the schematic properly. It may be that I just modified it wrong but I have been over it several times and I just can't find the problem. It sims fine but won't work right for me.
Thanks, Terry
I just got my PCB's today from Jason and plan on building a two channel stereo. I got two boards each:
Slewmonster 5P EF3 OPS
CFA-XH IPS
Are you guys running them off of standard dual-polarity (split) supplies?
Can somebody please recommend me a good "bang for your buck" transformer. It will be driving some Klipsch Heresy's so I don't need a lot of output power, they are 100 watt max, 94db, 8 ohm speakers.
CFA-XH IPS
I have one of these.
400VA Antek Power Transformers An 4234 | eBay
Pretty good bang for the buck. Will give you +-50V rails. The amp will run fine on that.
Hi Thimios,
Thanks, Terry
Hi Terry
My last modification is according to pdf on post 2974.
New configuration, asio driver
Asio driver based measurements.
The same with RMAA.
Amplifier is CFA simple.
