Com'on, your not that much of a NooB! Search!Who is "choky"?
But, I'll give you a hint: He was formaly known as...
if you want to make mosfet iteration - use exact schm from article
"second harmonic version"
increase number of LEDs to 3x green , plain ones , 3mm
good to go
Most soundcards will perform an FFT on the signal and that gives the display of the fundamental peak and the lesser harmonic peaks shown over the entire frequency spectrum. To show the distortion residual it's necessary to have either an audio precision, audio prisim, or some type of older distortion analyzer. I'm not sure if any soundcard software has a display of the residual.
Who is "choky"?
Your search turned out to be Zen Mod
Hello flg. The suspense was making me nervous!
Had anyone using sounds card with appropriate sw been able to show the residual signal like what Nelson did using his distortion analyzer. I haven't found any suitable sw that will do it.
Alex
Sent from my C6903 using Tapatalk
Might be worth investigating the latest version.
Exploring Visual Analyser (VA)
- F6 product announcement and owner's manual
