ooking forward to availability.
The queue has started already.
dave
dave
How to get in the queue?
Maybe already there?
Bob
I heard that the Alpair 10p(I own CHR-70) sounds quite good. However after visiting Bob Brine's website I noticed that this model exhibits high frequencies peaks above 4-5kHz.
I believe this phenomenon had been discussed before, I did not read the responses from these users/owners. My query is that do these peaks create any irritations among the users/owners, if so do you use any filters to suppress these peaks? If you do not experienced any irritations why not?
A response from anyone who has experienced this phenomenon is welcomed.
We run our A10p with nothing in between amp and speaker. Any measured resonances do not intrude, they have a somewhat laid back treble end.
A10p are very good, A10PeN better yet.
dave
dave
dave
thanks, btw why is the difference between 10p and 10PeN? any price difference or just a normal model upgrade?
Hi and yes.....
Hi bigaudioscotto!
Had a plan about that, but my router was a little too big(and didn`t have time to reposition it).
But I will make a suprabaffle or move my extra baffle from my old Fonken-styel box - so it will be more or less flushed in the end!
And the sound is so deep and bass-tuned - so even my Alp12P has to give up.🙂
Perfect - perfect
will give more pics in a day or two - time is short for fixing diff things!
Best
Olav
Olav.
I would flush mount the driver with baffle.
should make a big difference.
Hi bigaudioscotto!
Perfect - perfect
Best
Olav
Olav - Dave & I gave a quick listen to 10.3 in XLs last night - they were originally fitted with 10Ps, so need some extra fibre fill, but my yes the 10s can dig deep in this box.
My first listening impression of the 10.3 last year was that I preferred the papers, but with full break-in the metals are much smoother, and certainly have no trouble with Flight of Cosmic Hippo (Bela Fleck) , or Duende (Bozzio, Levin, Stevens) - my first go-to bass extension and articulation demo tracks
Hi Dave and Crisb....
Yea - too good to be true???
I was expecting some more fullbodied sound compared to the older Fonken-style I used, but it really blowed me out of my seat(The FHXL is more even and life-like). Nearly as good as my Alp12P in Fonkenlike boxes. They have more substance in the bottom octaves (FHXL I mean) - so they give a softer presentation of music. The Alp12P is more agile and clear(like a good Electrolytic speaker) - but the Fhxl is easier and more even.
I use the new Ryan Adams(come home) and Dream River with Bill Callahan to test them with for now!
Have to get my young daughter home now(at 20:00) - so off to service!
Best
Olav
Best
Olav
Some more impressions....
Hi again.🙂
Back from service ----
Like you said - I used more filling (around 20 gram more behind and 20 gram more in the front with pillow-stuff) to find the balance.
Have moved them down to my HarmanKardon 980 which gives more touch and has enough power to them. They need more than my homemade SIT-amp does give with its 2x10 W classA. The SIT-amp has enough power for the Alp12P!
I am planning a preamp with a sparecouple SIT-transistors I got(2SK82). A project for the september/october month. And maybe it will give more power than my passive B1
Time will tell.....but for now, they both - Alp12P and Alp10.2 in Fhxl - is so fullfilling sonic!!
Best
Olav
Hi again.🙂
Best
Olav
Olav
Here is a good way to do it.
Take a 3/4 piece of mdf and cut a hole the size of the outside circumference
Of your 10p make sure it is a large enough piece that the router can sit easily on.use double sided carpet tape around hole on baffle to hold the template you
Made.lay the mdf template over baffle hole eyeballing to get it perfect edge distance around perimeter of hole.now you are ready to route the hole
You will need a pattern template bit for this now just measure the depth of the
Plastic surround on the 10p and cut to that depth.
Good luck.
Scott
Good luck.
Scott
Hi bigaudioscotto!
Perfect - perfect
Best
Olav
Spl on Alp10.2...
Hi Dave.
Yes - not much difference between the paper versions. But the ALP10.2 has a 87db Spl (information leaf) and the ALP12P has 91db Spl.
And that should be something to give in soundpressure = 3db is a doubling - according to my oldtimer teaching(remember I`m passed 60 - and still hearing around 15000 Hz) I think using noise-stoppers at work is a good help - plus a daily meditation helps on how you tune in to sound/music.
And to bigaudioscotto - thanks for tips and ways to make the couple even more perfect. Will try something when time permits.
Some more pics....🙂
Best to all
Olav
By my measures only about a dB sensitivity difference between A12p and A10p
dave
Hi Dave.
Some more pics....🙂
Best to all
Olav
Tnx Sippy....
Yes - they nice as plantholders.... but I need it for the moment. Haven`t glued the top and with a rubber-band around top - it is good to keep the top at place. It can nearly start flying with the pressure inside- well not exactly. But you can feel the pressure when playing with some level!
Best
Olav
Nice plant sta..... speakers there Olav 😀
Best
Olav
Brain fade on my part forgetting that you were using A10.2
dave
- Full Range
- Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more
