Photo Gallery
EML 300B mesh driven by c3g.
Heaters supplied by a Coleman board.
Interstage coupled (a really well sounding Tribute on amorphe core).
A lot of Tamura irons. Including the famous F-7003 (5K). A little pain for my wallet but a plesure for eys and ears.
Case with frame of walnut wood matching a Corian top.
Dovetails joints on edges.
Professional Neutrik (sepeakon, powercon and rca) connectors which I found more reliable and good quality made for a fraction of the price of "audiophiles" ones.
Gain enough to be driven directly by the DAC (Buffalo I).
Very, very good. Great work. Beautiful amp.
Whats the idea with the copper tube and elbow.
Tamura F-7003 & 845
Beautiful amp Popla.
An interesting coincidence, this is my 845 SE 10W amp, 2 stage design using Tamura F-7003. Input tube is C3GS (nude) in pentode mode (plenty of gain), capacitor coupled to 845 tube. Beautiful sound when mated to my Stacked Quad/RTR tweeter, now it power my Tad2001 horn.
Wish we can compare the two amps sound!!!!
Fantastic look.
The tube I thank is a WE437 but is a C3G without shield.
It should be a shield. Not for mains cables but for signal input cables.
I don't have any metal part in the case and the amp is placed in a bookcase with tons of electronical equipments around. In ls than two meters:
- TV
- Children's PlayStation
- Children's Xbox
- Children's Wii
- Cordless phone
- Router
- Multimedia HT-PC
- DAC
- Blueray reader/writer
not all switched on at the same time but enough to make some noise.
PloPla.....great work.Congrats.
Why did not use all the iron from Tribute?...or Tamura?
Diagrams to share??
Thanks.
What speakers did you drive with this?
I have a couple of Tamura B-5003, but the Tribute.....
Speaking around seems a miracle to have been able to receive a couple of Tribute in a relatively short time.
I'll ask him for some more for shure, excellent products, but I know you have to wait.
I don't have a diagram.
But is not a difficult.
- Double choke supply in common mode (half each on the positive side, half on the negative).
- 5u-10mH-70u-10mH-210u-R-70u
- A blue led under the c3g to get -2.8V on the grid
- A power zener 68V under the 300B
- B+ 390 (including the 68 on the grid)->65mA
- B++ 200V
- Interstage
- grid stopper 1k
- grid resistors 100k on both tubes
C3G/300B
Yes, that was C3G driving 845. I took the shield cover off exposing the tube, I call it C3GS nude.
Below is 300B PSE amplifier. Input tube is also C3G painted. Amplifier has tube regulated power supply and oil cap. Originally it was a 3 stage SE 300B with interstage, C3G input driver 300B with interstage driving a SE 300B. It has been changed to 2 stage 15W PSE300B, but it can also be modified to 8W SE 300B without much work. Output transforner is James.
Fantastic look.
This is the Audioromy FU29 pp amp, the main issue with this amp
is "red plating" since cathode is common to both sections,
the only way to balance currents in both plates is thru fixed bias....
(actually there are two other mods that can be done, one is by manipulating
the filament voltage, and the other by tweaking the screen grid voltage
from its set point of about 200 volts....i am looking to implement these
in my upcoming 829b builds)
in order to fix the issue, i changed bias to cathode resistor bias instead...
a 270 ohm 5 watt resistor drops 17 volts, so that at idle, total
plate dissipation for both tubes is about 26 watts, so that either
plate is dissipating about 13 watts...remember that this tube can dissipate 60 watts...
so that longer life expectancy for the 829b is more or less secured.... 8)
before mods..
after mods..
other mods included changing plate caps to ceramic type...
the nylon type used was actually a solderless connector...
Yes,I talk with Pieter from Tribute many times and I know his work ...very good indeed....and core used is outstanding.
Still.....what type of speakers do you have for this amplifier?
Thanks.
Ooops, sorry, I forgot to answer to your question.
JBL 15" 2226H in BR 90 liters + B&C 2" driver DCM50 with StereoLab horns Tractrix 250 + Fostex T925
Filters round 500Hz and 5.000Hz
Efficency round 96 db/W
