.....sorry , but missing some small heat sinks . Driver transistors and predriver will burn
Regards Alex
Regards Alex
Alex I have tested pcb made by you with this layout couple of year back and driver transistor is mounted on heatsink, mje340 and mje350 barely get warm. I did tested with 80VDC supply. one can put heatsink to be safe. nice pcb you made very compact.
Hi to all I have a question about sr 200.I made the sanken version pcb by Alex MM with one pair of 1943 5200 just for testing and with the zobel network that was included on pcb I couldn’t adjust the bias it stayed at 4.5 ma ,but without it everything was ok the amp worked to my ears very well . I also include the two 1n4007 diodes was missing from the pcb .And I must say that i don’t have an oscilloscope to make more measurements .Is that normal or not?
Thanks!! 😕
Thanks!! 😕
SR 200 first steps![]()
Hi thimios,
i want to know the size of sr200 pcb for sanken output transistor that you have made.
i want to try to build this amp.
thanks
dear alex mm
may i know the size of sr200 pcb for sanken output
i want to make the pcb for my own, because i have 4 pairs sanken 2sa1295/2sc3264 that i never used.
i need your information
Hi Alex ,can you give this in pdf format?Hi TeHaa
You can try my last PCB for Sanken transistors , size 215 mm X 80 mm 🙂
Regards Alex
Best regards.
Thimios.
Best regards.
Thimios.
....yes of course , why not , here in attachment are all files for toner transfer metod 🙂
Regards ,Alex
Regards ,Alex
Thanks Alex...
Regards ,Alex
Hi Alex, excellent PCB, as usual 😉
Can you please also drop here a P-CAD ASCII?
Thanks Alex.🙂🙂....yes of course , why not , here in attachment are all files for toner transfer metod 🙂
Regards ,Alex
Hi TeHaa
Regards Alex
Thanks alex mm for the information
SR200 layout by ALEX MM
- Studio Reference Amplifier
