Driver for XMOS behave like virus, try to find it in registry..
XMOS Driver behave like virus don't understand,
*1 Got the XMOS to SPDIF stand-alone unit...cannot get it to work under Xubuntu.
Velujov have you tried your xmos akm with ubuntu or other linux distro?
Just another proof of poor implementation of chip..
Try Voyage MPD | Voyage Linux..
Thay say USB Audio Class 2 support (allowing 24bit and up to 192Khz sample rates). It works best on XMOS chipsets
If it does not work on it means that the structure is completely wrong..
Hi I have noticed minishaw have disappeared from eBay.
I had there USB card on my watch list and it's been removed.
If you go to there shop it says 0 items.
Not correct ..
Try to write only when you have anything concrete to say, by now you've written a bunch of unsubstantiated claims ..
Not correct ..
I am not looking for a argument I was just letting you no I had one of there xmos USB dac pcb on my watch list and it was removed.
When I tried to go on there shop on eBay via the link it shows minishow have no items for sale.
Perhaps it's just in the uk but I no what happened when I tried to look for there items.
That's normal if the seller is away (like a vaction or similar.
It's not possible to see what he sells at all. Same with other sellers.
Driver 1.61 and 2.10 doesn't work in Windows 8 and 8.1
BUT if you fallow this carefully you can make it work 🙂
Just go "general" and startup in recoverymode and choose troubleshoot and when pc restarts you choose alternative or key 7, install the driver and restart again and voila.
See link:
Preinstallation failed! Please run setup again. If you are asked to confirm installation of software, please confirm.
See link:
Only confirms how miserable is support for xmos.. or, more correctly, how ebay sellers do not try to exploit options of chips which use..
Here is some kind of solution for opamp output.. it is easy to solder on the existing board..
There will certainly play far better than the output as it is now..
This design allows you to really hear the difference between opamps, my recommendation is definitely LT1363 ..
Hi! I see in this board I2S output, but can I use It like input? I want to connect my Raspberry Pi to this DAC using I2S interface - it's possible?
Sorry, I talk about this plate in version with some pins nearly of USB IC (I suppose, that is I2S, but may be I can use it like I2S Input?
I have the same plate with 49710(Chinese) on board and change it to 49710ha (not from China). Difference is huge. Don't you think chinese one is a fake one?Finally in the box ..
In the end I chose the version of the output as shown in the image ..
LT1363 definitely work better than LME49710 ..
Have somebody windows drivers for this device?
NEW XMOS USB 7 pin Asynchronous daughter card For AK4399 / DAC7/ ES9018 -SN
- Digital Source
- Xmos and AK4399 in single board
