First off who was watching wrestling when you could have been watching the Thunderbirds and real roller derby?
No, not thunderbirds..1.2.3.4.
Better was Fireball XL5. Second was Supercar..
Marionettes?
Yup, both. And apparently sometimes TT's.
Ed, you simply don't understand the basics at times. I for one am tired of these discussions. Maybe jn wants to elaborate on the differences between the EM wave and charge.
To what purpose?? Arthur C Clarke had it right.
I thought that the signal and return current travel at the same time as a wave, are we saying here that it is like a train track, with the positive signal traveling down one wire then back up the other wire?
Puzzled...
Pipes...plumbing and bb's..forget the waves...
jn
SE,
Those insane turntables with huge mass seem to be most concerned with speed control and using the high mass to keep speed constant.
Then how do you explain a 100 pound plinth and a 300 pound stand. 😀
Funny that they don't also have a clamping system to tie the vinyl to that moving mass sometimes. A bell jar with a vacuum attachment would solve all the other problems one may think up.
They'd just think up another problem.
se
SE,
Some of the incredibly heavy plinths and vertical masses I have seen must be a damned load on any motor to get going from a stop. I understand the concept of a heavy mass keeping a constant velocity but it seems rather overkill many times. I didn't say that none of these turntables don't clamp the vinyl or even use a vacuum system to hold the vinyl down but some don't seem to do that I have seen in the past. I'll just have to do with my old direct drive and Dual turntables for now. I think I would build my own before paying someone the price for any of the commercial products costing such big bucks. Joachim seems to be a very good source for information on diy turntables and arms.
> (The wise may look at using a 240 volt primary
> on a 120 volt line with four output windings!)
By " 4 windings " do you mean 2 / channel ?
Right about the 240 V primary
( remembering to maintain the current capability of the secondary )
What does the 240v primary do for you? Is more L from more windings on the primary better to choke out the line noise? Do you phase the secondary windings to cancel unwanted noise, is that why four?
