4 x BTL 300W/8R - a TDA8950j based 4 channel power amplifier
Joined 2011
*** NOTE: latest gerbers in post # 81 *** NOTE ***
Just 4 fun I have designed (now some years ago) a 4 channel class D power amplifier to get some feeling and knowledge about building class D amplifiers.
Attached some schematics and pictures of the result.
After searching for a simple chip I found the TDA8950j which has from low to mid range an acceptable good THD performance.
The TDA8950j can be clocked externally which I have used in this design to avoid interferences of the different pwm clocks in the audible range.
Maximum output power per channel is 300W/8R.
The amp pcb is single sided and uses some smt devices to save space and to fulfill some datasheet requirements.
For DIY use only feel free to build your party power machine.😉
BR, Toni
  • class_d_preamp_powersupply_schematic.pdf
  • tda8950_btl_schematic.pdf
Reactions: stewin
Some more pictures and schematics.
Gerber file for amplifier pcb.
BR, Toni
  • class_d_powersupply_schematic.pdf
  • tda8950_btl.zip
    tda8950_btl.zip
Good job, congratulations, but the maximum power output can not be 300W/8Ohm/channel when loading circuit to + / 35VDC. Power can reach max.150W/4Ohmi/ch but with high THD (~~10%). Remember, the human ear begins to perceive distortions if THD reaches about 2% (or more so). For this reason "audiophile power" of that TDA is at most 100W/4Ohm/channel (but stamp sound is far below the desired).
Seriously? WOW 😀
BR, Toni
Really, this is just awesome, I mean real classy, great cabling and layout and great finish.. The finish is of commercial worth and it would fetch you a high amount if you decided to go commercial.
Excited to see your build and will be hoping someday i could do the same.
THX for your nice words!
BTW: Building different amplifier topologies is just a hobby for me. Everybody can reuse my designs as long as this is done for non commercial DIY usage only.
BR, Toni
I wouldn't use this amplifier for audiophile listening - party mode!😉
Hi Toni
I'm curious... what you mean by you wouldn't use the amp for audiophile listening?
I explain, I am new to Class D and I don't know if what I hear is a defect inherent to the TDA8950j or there is a design problem. At mid to high power it sounds very well, but from silence to 10w or so (I didn't measure anything yet) I hear a pretty audible distortion, likewise the old famous crossover distortion known on poor calibrated Class AB amps... is it a weak point of Class D, of TDA8950j or a serious problem with my amp?
I didn't build the amp, it was made by another guy who told me it is normal, that the amp is intended to be used at high power. Is that so?
My doubt is because reading the datasheet of the chip the real life result is not consisten with the 0.05% THD @1watt 8 ohm load. My amp is also BTL mono configuration.
Thanks in advance!
Rei.
Hi Toni
The TDA8950j has definitely a THD problem in the 5 - 7 kHz range which can be heard playing special audio material e.g. piano music.
This THD problem can be seen in the datasheets too. I have verified this problem using my Distortion analyser VP7723D. Own THD plot compared to the datasheet is nearly identical, so it is not a problem of the implementation.
I'm currently in the process removing the TDA8950j stages and replacing them with IRS2092 based bridging amplifier modules.
Have a look at this project for further information:
http://www.diyaudio.com/forums/class-d/255046-systemd-liteamp.html
Results will be posted in above thread and maybe also here or in a separate thread.
Stay tuned,
Toni
astx,
TDA8950 when operating in BTL mode to give more power what happen if your amp load drops below 4ohms?
I bought a commercial TDA8950 and configured it into BTL mode but my spkrs is about 3-4 ohms, the ampl. crashed, i.e. failed and never recovered. Luckily my spkr is still ok.
Any explanations.
Toni
I can't see this. As far as I can see the THD stays well below 1% (more like 0,1% above 6 khz). Is this really audible or is it something else.
I have heard some artifacts playing piano, but I mounted the print wrong, so I expected this to be the problem. I will have a new amp up and runninge in the next few weeks, then I can comment on the full range qualities, and if I still have the artifacts on piano recordings.
Toni,
I was thinking of using your design four a bass guitar amplifier. Do you think the distortion means it is not OK for me?
This is exactly the same application I intend to use my amp, for my bass guitar, but in the first run I "hear" a distinctive distortion at low level, let's say less than 10w output into 8ohms. After Toni's reply I read again the datasheet of the TDA8950j and in theory the THD figure would be not an issue to play the bass, even with all the treble up in order to emphazise the fret whip on a slap, a bit of distortion there would be part of the charm for the performance 🙂
But I injected a sine wave of 30Hz and I hear a buzzing tone. Unfortunately my scope is broken at the moment, once I got it repaired I will take pictures to show what I hear. For my experience seeing and hearing waves surely I will find the classic distrortion at the zero crossing of the sine wave...
I made the 30Hz test just because at low power I would rather feel it almost like silence and then I found that buzz clearly right at the begining of the volume rise from zero!... I have to add that I made this quick test after I heard the distortion right away when I put the first CD!!!.. it means, all the frequencies from low to high.
I am inspecting the board and I'm seeing something weird at the inputs, the differential inputs are not made according to the datasheet example, it appears they are not properly DC isolated with caps.. it's getting hard for me to see it right because they also made it almost all surface mount, but I try to verify if there is some mistake in the board.
A bad designed input could be the source of distortion I talk about? is it possible to generate a crossover distortion at audio level before pulse modulation if the input is implemented in the wrong way?
Rei.
