Let's do a blind test!
Look at this .
25Vpp /200KHz/4R DUMMY LOAD.
I want opinions.Then I will reveal the exact version.
Thimios.
Did you modify the schematic?
No bimo this is from an unmodified schematic..😱 😎
I see. May be my amp can do that. But I do not have good square wave signal generator up to 200kHz. Anyone have simple schematic that can produce good square wave signal up to 200kHz?
Look at this .
Thimios.
i do not think it is cfa-x....
Here's hoping we see some of OS's refinements to the CFA-X from the 'other' thread here soon (the CFA-XH)... I think I'd jump on that right away! A giant VSSA 😎.
OK , I will begin.
(below 1) is the "H" version of the CFA-X.
This IPS "burns up the road".
5-12ppm (1k/20k) with 400v/us slew ( in a more "tame" mode).
It will run with NO compensation ! Amazing.
Easy to make the IPS , just graft my already- made Hawksford layout
to the "CFA-X". 🙂
Some say I should add the servo/floating CCS plus cascodes to the
IP pair. Nope ... "KISS" (keep it stupid simple), is the better way.
Easier just to use something like D667a/B647a to "harden" the IP
pair. (many other choices for 10 Cob - 100Vceo - 1A devices).
OS
Ostripper,
Hoping to recieve my Slew boards this week and then I've to decide which IPS board I take but you've designed so many.Don't know which one to take anymore.
Ostripper,
I'm kind of leaning toward the original "CFA-X" -or this update to it ,for my
own OPS's.
I love the hawksford sound (so does luxman - even their preamps
have this for op). I must satisfy my UV/red led fetish ... this
amp must look "tubish" 😀 .
(below is the reason) !! Mama ... I forgot the caps !! 😱
OS
I would not try this in the real world 😀 ... but it is a good
example of this circuits "slop" factor (VERY wide margin for error).
Also , don't try shunt comp. with the "gnome" (dadod has one oscillating
on the CFA thread). On this PCB , I will allow for either miller or shunt ...
just to be careful.
PS - the slew on my last attachment was 1.2KV+/us (estimate) with 6mhz UG. that's as
far as these models can go. (amp limited by Cob)
OS
So OS,
I assume you wouldn't really want that ringing on the square wave even at that insane slew rate, will there be some compensation scheme to tame that circuit?
So OS,
Your suggestion creates a interesting possibility.
(below 1) is realistically fast. while it does slightly ring , it is stable ...
I saw some of the more aggressive tests that thimios did.
With trimmable capacitors like Thimios used , you could just "dial in"
your desired slew.The predicted range would be 60V/uS to over 600V/us
(with the trimmer).
(below 2) is 68p comp. (slow - like a VFA😀) , with a 100pf mica
trimmer cap (below 3) .... interesting comparisons could be achieved.
I must say those are the first adjustable caps I have ever seen. For those of us who don't currently have access to a nice O'scope will the bom and specific part numbers and values give us a workable solution without having to worry about oscillations?
Those with scopes could trim to perfection and enlighten the rest. 🙂
A "safe" value is 100k/27-33pF - no ringing at all ...300V slew.
I have started the PCB. it will also appeal to "tweakers" ... multiple
compensation options.
PS = "adjustable caps" .... open up a hi-fi tuner or receiver, the rf "front end" will have them.
OS
Look at this .
Thimios.
Out trans.2sc3264,a1295.
D5, D6 needs decoupling, lower noise tooOK , I will begin.
to the "CFA-X". 🙂
OS
R2 lower to 10-22 k
Feedback resistor sets the gm, so indeed if the feedback resistor is of the appropriate value, you can in theory skip the comp cap. However, I think in these cases you will be relting on the intrinsic capacitance of the TIS/TAS and any capacitance load from the TIS/TAS output to ground (can be 10s of pF in a practical amp)
R2 lower to 10-22 k
I will "make it so" .... HF noise , .01u ??? They can be very low
voltage (cheap) .. no big issue.
To rate this amp .... it has the THD20 of the "leach/spooky" and
even better slew/ SW behavior than the "NX" (diamond buffered).
Between those 2 factors ... it is best (at least in sim).
OS
- Slewmaster - CFA vs. VFA "Rumble"
