If you have say 1500uF or more at the preamp then I would put the Kmultiplier as close as you can. Otherwise don't worry. You could also test this yourself so we know for sure. There has not yet been a lot of testing with the KM specifically, but the same rules should apply for umbilicals in general.
OK. Thnak to both. Another question, Andrew. When you say HF impedance, are we talking 100K level or 20k level. I know there is a fascination with bandwidth levels far beyond our ability to hear. At what levels are we losing here.
I will redesign the preamp board to include the K-Multiplier on board. To keep it close, i would have to redesign it anyway.
Hi Keantoken,
I want to use your CFP for the LME49830, as you recommended me for filtering. As I need 55V the circuit from post #600 should fit this. Is this also the newest version of the circuit?
D1 and D2 have to be trippled... sorry for the question but does this mean parallel or in series?
Many thanks,
Stammheim
Many thanks,
Stammheim
Hi all,
Please see my post for KM on Salas Folded Simplistic Phono PSU. It is retarded to KM integration and PSU improved operation.
Post # 12512
http://www.diyaudio.com/forums/analogue-source/129126-simplistic-njfet-riaa-1252.html#post3893278
Post # 12512
Yes, I do.
alex***@gmail.com
I meant: I sent you and e-mail
I've added 2 schematics to the "other adaptations" section of my Kmultiplier webpage which you can find in my signature. This includes the schematic for the version I built for AlexKosha.
Thank you Kean.
I will build the last version and will post here my subjective opinions.
- Power Supplies
- Keantoken's CFP cap multiplier
