Very Good. Should sound excellent.![]()
Nice Amp!What is the power output?
Thank you fellow DIYers.
I have the B+ at 1100vDC for the 845 on a 10K OPT probably delivering around 18W output.
PP EL84, Bevois Valley -style
I made this amp mostly from recycled components and transformers. Much like from Morgan Jones' book but PS is my own design, output tubes are triode connected and EM84 VU-meters added. Cover for transformers is still a work in progress and some other minor details.
The large white caps; motor starts or motor runs or Fluro caps?
Ta!They are 50uF 450VAC motor run polypropylenes, salvaged from trash bin.
Where did you take the signal for the VU meters from?
They are connected to input resistors.
I have the same meters,I wasn't sure how much signal I would need,They are connected to input resistors.
Thanks.
Thanks.
I have adjusted the sensitivity trimpots almost to maximum.
I would like to show my last tubes amplifier using 100TH in s.e. with 316A drivers.
Amazing!😱
- Tubes / Valves
- Photo Gallery
