The 1n540x is much bigger and requires much bigger through holes for mounting.
I also fit 1n4003 across the first decoupling caps (after fuses, if fitted). This protects against accidental mis-wiring of the PSU cabling (it turns on the light bulb, or blows the close rated mains fuse).
These four 2cent, (1.5p) diodes are life savers.
for the 2SC5200/2SA1943 driver stage, I suppose Fairchild devices will be ok
due to the almost 100% non inductive construction, a power thick film appears attractive for the 1R emitter resistor
and not too costly either
but is it ok for this position ?
Any of them would be OK.
Sajti
How did you arrive at this conclusion?..........................due to the 100% non inductive construction,...............
Is that heatsink enough for 1000W class AB?
Sajti
forced air cooling
possible only with the protection curcuit shutting down if fan fails or amp is overloaded
or maybe the pink panther color is something secret
forced air cooling
I know, but this heatsink even small with forced cooling too.
Yes, the protection will help to avoid the failure resulted by the overheating. However the amplifier will stop, and this is not a good solution for professional application.
overload detector for 1000 watt AB CLASS
Hello
greetings can anyone share overload and low impedance detector for this amp cabinets are ready supply pcb has clip dc protect temprature shutdown
filter caps would be 15000 uf 4 caps only wish if overload detector circuit can be added
warm regards
andrew
Hello
warm regards
andrew
... amplifier will stop, and this is not a good solution for professional application.
wouldn't testing and knowing your gear help avoid that ?
but are anyone running amps at full blast clipping ?
The maximum dissipation of the class AB amplifier, is at the 33% of the maximum output power, and not at the clipping....
Sajti
.... solution for professional application.
I expect professional application means active crossovers and multiple amps ?
No, that means, that You make money with the amplifier.
Sajti
- 1000W Simple PA Amplifier
