Lol! Yeah, they're tricky.
When you look at the spec sheets, be sure to look at the number of windings, and when they give a ratio you have to see if they're specifying it for series/series, parallel/series, etc.
JT-112-LCF JT-11-FLCF - Datasheet Archive
1:2 CONFIGURATION LINE OUTPUT TRANSFORMER QUADFILAR WINDINGS M M M M M Distortion 0.032% typ at 20 Hz and +4 dBu output level
JT-112-LCF JT-112-LCF 1:2 CONFIGURATION LINE OUTPUT TRANSFORMER QUADFILAR WINDINGS M M M M M Distortion 0.032% typ at 20 Hz and +4 dBu output level Wide bandwidth: !3 dB at 0.27 Hz and 370 kHz Drives 600 S loads to levels up to +21 dBu at 20 Hz Excellent time domain performance: DLP 0.3E typ 20 Hz to 20 kHz E Loading loss only 1.5 dB when driving 600 S load This transformer is designed for use as a 1:2 step-up for line output stages operating from low voltage rails. For 1:1 applications consider the JT-11-FLCF JT-11-FLCF. The 50% nickel core alloy has excellent level handling and low distortion.
I just spoke to the very nice people at Jensen and they are going to do a run of the transformers. They asked me to let you know that the JT-112-LCF has been re-numbered and will now be called the JT-123-FLCF, which is just the wire-terminated version of the JT-123-FLPCH, which NP used in the F6 project. So, the two are interchangeable, just terminated differently.
The take-away here is "four identical windings". I've seen a model or two mentioned in this thread that only have two windings.
@dady:
I see four wires sticking out of it. One primary, and one secondary. Am I looking at the right one?
And, may I (just out of morbid curiosity) ask what's wrong with using parts that have been specified?
"with primaries in parallel"
You are right, should have looked better at the datasheet....
Not just a quick browse 😱
Walter
I've opened up a thread to better guage the interest of a GB:
http://www.diyaudio.com/forums/grou...ansformers-sony-vfet-project.html#post3869493
Thanks,
Dennis
Thanks,
Dennis
JT-11-FLCF is the right so. Quadrifilar 1 to 1.
JT-11-FLCF is not right.
Quadfilar, yes.
I mean JT-112-FLCF.
Am I illness by dyslexia?
Quadfilar is enough number of windings?
Thanks Michael and good night, at least we have a defined goal.
Yes, I think we're on track.
The JT-112-LCF (which is marked JT-112-L on the tape) will soon be known as the JT-123-FLCF as Jensen informs us they'll be renumbering it in the near future. It's just a matter of wire termination vs. PCB pins. I'm sure they will understand what is intended should anyone order the old part. For those building a PCB, the FLPCH is the applicable part.
Good night. 🙂
Good night. 🙂
- Article - Sony VFETs part 1
