Vacuum Tube SPICE Models
I create tube models of my own tubes by using a Tube tracer developed by a Dutch engineer (Ronald Dekker) and an ExtractProgram from Derk Reefman using the Tube tracer data. This results in an exact model for LTSpice and the project I want to realise. Many audiophiles have built their Tube Tracer, called uTracer, over the whole world. I give here the link to the site where you can find all info about this super device. (The uTracer, a miniature Tube Tester / Curve Tracer.).
So, I haven't looked around yet, so pardon my laziness, but anyone have a spice model for the KT120 from TungSol?
I haven't tested this, but here ya go...
Code:
.SUBCKT KT120   1 2 3 4 ; A G2 G1 C
* New Sensor website
* library format: LTSpice 19-Sep-2008
X1 1 2 3 4 PENTODE1 MU=9.14 EX=1.350 KG1=612.3 KG2=4500 KP=31.40 KVB=20.0 VCT=0.00 RGI=1000 CCG=29.0p CPG1=1.8p CCP=10.0p ;
.ENDS    KT120
.SUBCKT PENTODE1 1 2 3 4 ; A G2 G1 C
RE1  7 0  1MEG    ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1   7 0  VALUE={V(2,4)/KP*LOG(1+EXP((1/MU+V(3,4)/V(2,4))*KP))}    ; E1 BREAKS UP LONG EQUATION FOR G1.
G1   1 4  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,4)/KVB)}
G2   2 4  VALUE={(EXP(EX*(LOG((V(2,4)/MU)+V(3,4)))))/KG2}
* G2   2 4  VALUE={PWR(V(2,4)/MU+V(3,4),EX)/KG2}
RCP  1 4  1G      ; FOR CONVERGENCE    A  - C
C1   3 4  {CCG}   ; CATHODE-GRID 1    C  - G1
C2   1 3  {CPG1}  ; GRID 1-PLATE    G1 - A
C3   1 4  {CCP}   ; CATHODE-PLATE    A  - C
R1   3 5  {RGI}   ; FOR GRID CURRENT    G1 - 5
D3   5 4  DX      ; FOR GRID CURRENT    5  - C
.ENDS PENTODE1
If this model doesn't work for you in TINA, let me know. 🙂
Here's a triode connected KT120 I found on Tube DIY Asylum
Code:
* KT120So2k8 LTSpice model
* Modified Koren model (8 parameters): mean fit error 1.664mA
* Traced by erik 25/12/2013 using Curve Captor v0.9.1
* from sofia tracer
* kt120so2 LTSpice model
.subckt kt120so2k8 P G K
Bp P K I=(0.09616726061m)*uramp(V(P,K)*ln(1.0+(-0.1983471212)+exp((0.5067247971)+(0.5067247971)*((28.86336585)+(2.153515075m)*V(G,K))*V(G,K)/sqrt((-0.1596450898)**2+(V(P,K)-(-9.567928489))**2)))/(0.5067247971))**(1.391876027)
Cgk G K 10.2p ; 0.2p added
Cpk P K 9.3p ; 0.5p added
Cgp G P 29.5p ; 0.5p added
Rpk P K 1G ; to avoid floating nodes
d3 G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends
That looks like a fun project! thanks.
Code:
.ENDS    KT120
.ENDS PENTODE1
Thanks, but no, it doesn't compile or what ever macros do to become something useful in Tina. I think Tina only recognizes "P" for plate, for one thing. I don't have any information about Tina's macro language so I'm completely clueless except for banging my head against the wall.
I made "P" and "K" consistent throughout and it still doesn't work:
.SUBCKT KT120 1 2 3 4 ; P G2 G1 K
.ENDS KT120
.SUBCKT PENTODE1 1 2 3 4 ; P G2 G1 K
C1 3 4 {CKG} ; CATHODE-GRID 1 C - G1
C3 1 4 {CKP} ; CATHODE-PLATE A - C
.ENDS PENTODE1
It shows up in Tina as some kind of weird thing that I don't recognize.
Well known here, several of us have one. I find mine extremely useful, can't imagine a more useful tool for characterizing tubes and also creating models for spice.
I have not yet tried Derk's algorithms, but plan to relatively soon when I return from phono pre-amp design hell.. 😀
Sorry about that. This one works in TINA.
Code:
* KT120 Pentode
* Connections:
*               Plate
*               | Screen
*               | | Grid
*               | | | Cathode
+ PARAMS: MU=9.14 EX=1.350 KG1=612.3 KG2=4500 KP=31.40 KVB=20.0
+ VCT=0.00 RGI=1000 CCG=29.0p CPG1=1.8p CCP=10.0p
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS KT120
Someone is looking for a pentode model for type 32 over at yahoo groups, could one of the uTracer users be kind enough to trace one and generate a model for him? He is particular interested in the low plate voltage region, so none of the tools like Ayumi, PaintModelTool works...
As usual, I use the Ayumi model, here is the comparison with the Philips datasheet:
Here is the model:
Code:
* Generic triode model: ECC88
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Mar  8 22:42:43 2008
*             Plate
*             | Grid
*             | | Cathode
.SUBCKT ECC88 A G K
BGG   GG   0 V=V(G,K)+0.34001426
BM1   M1   0 V=(0.009343174*(URAMP(V(A,K))+1e-10))**-0.49661195
BM2   M2   0 V=(0.75127268*(URAMP(V(GG)+URAMP(V(A,K))/26.621288)+1e-10))**1.9966119
BP    P    0 V=0.007130155*(URAMP(V(GG)+URAMP(V(A,K))/35.434921)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0041180199*V(M1)*V(M2)
BIG   IG   0 V=0.0035650775*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0038690245*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 1.4p
CGK   G    K 3.3p
CAK   A    K 1.8p
.ENDS
Here is the model:
Code:
* Generic triode model: ECC33
* Version 3.10, Generated on Sat Mar  8 22:42:38 2008
*             Plate
*             | Grid
*             | | Cathode
.SUBCKT ECC33 A G K
BGG   GG   0 V=V(G,K)+0.39854224
BM1   M1   0 V=(0.00456874*(URAMP(V(A,K))+1e-10))**-0.2251333
BM2   M2   0 V=(0.86949802*(URAMP(V(GG)+URAMP(V(A,K))/28.564106)+1e-10))**1.7251333
BP    P    0 V=0.001087821*(URAMP(V(GG)+URAMP(V(A,K))/32.85126)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00070978374*V(M1)*V(M2)
BIG   IG   0 V=0.00054391049*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.00059395688*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 2.5p
CGK   G    K 3.5p
CAK   A    K 1.5p
.ENDS
Your model is for the ECC33. I didn't think this was equivalent to the ECC88 (6DJ8/6922).
